VIC 340 #590841
01/22/10 03:44 PM
01/22/10 03:44 PM
On the south side of Nowhere
S/ST 3040 Offline OP
I still have some epoxy work to do since this was used and the
previous owner "port matched" it already.
Re: VIC 340 [Re: S/ST 3040] #590842
01/22/10 03:51 PM
01/22/10 03:51 PM
OOTB Victor 340
Re: VIC 340 [Re: S/ST 3040] #590843
01/22/10 03:56 PM
01/22/10 03:56 PM
Re: VIC 340 [Re: S/ST 3040] #590844
01/22/10 04:00 PM
01/22/10 04:00 PM
x 2
Re: VIC 340 [Re: S/ST 3040] #590845
01/22/10 04:06 PM
01/22/10 04:06 PM
OOTB x 2
Re: VIC 340 [Re: S/ST 3040] #590846
01/22/10 04:12 PM
01/22/10 04:12 PM
x 3
Re: VIC 340 [Re: S/ST 3040] #590847
01/22/10 04:16 PM
01/22/10 04:16 PM
x 4
Re: VIC 340 [Re: S/ST 3040] #590848
01/22/10 04:20 PM
01/22/10 04:20 PM
OOTB x 3
Re: VIC 340 [Re: S/ST 3040] #590849
01/22/10 04:25 PM
01/22/10 04:25 PM
x 5
Re: VIC 340 [Re: S/ST 3040] #590850
01/22/10 04:30 PM
01/22/10 04:30 PM
Stage 1 Lightening Program.
Re: VIC 340 [Re: S/ST 3040] #590851
01/22/10 04:54 PM
01/22/10 04:54 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm running the same manifold on my 408. Did some top work ( blending in to the runners like yours), but not as much divider work ( knife edging )as you have. Not sure knife edging is a good thing or not? I did port match at the heads - in about 2".
Fastest 300
Re: VIC 340 [Re: Crizila] #590852
01/22/10 05:02 PM
01/22/10 05:02 PM
I left all the dividers as round as possible.
I wish I could saw these in half and do it right.
Re: VIC 340 [Re: S/ST 3040] #590853
01/22/10 06:39 PM
01/22/10 06:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... you mean like this Vic.... but this is for a
W-9... I milled the upper to fit a 1050 dom... most
of all the port work is done but I need to put it on
my engine to weld it back together for proper fit
EDIT
this was a VERY early casting that I ended up with,
was really rough inside as you can see.... I didnt
want to do this one the hard way... WAY to much work
Re: VIC 340 [Re: MR_P_BODY] #590854
01/22/10 07:16 PM
01/22/10 07:16 PM
Yes but, it would suit me better to split it front and rear.
Re: VIC 340 [Re: S/ST 3040] #590855
01/22/10 07:23 PM
01/22/10 07:23 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I think it looks real nice
You should see how sharp the port divider walls are on my X-Celerator
Thay were sharp to begin with and if I wanted them rounded like yours I'd have to take an inch out of them
Again real nice job and should work well for you
Re: VIC 340 [Re: roadhazard] #590856
01/22/10 07:55 PM
01/22/10 07:55 PM
Thanks. The flash makes the finish look like &$%%*!
Hopefully, I didn't hurt it by more than 5 or 10 HP.
Re: VIC 340 [Re: S/ST 3040] #590857
01/22/10 08:03 PM
01/22/10 08:03 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
that kinda looks like my M1 that somebody on here did
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: VIC 340 [Re: S/ST 3040] #590858
01/22/10 08:05 PM
01/22/10 08:05 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yah right.....
More like helped it
Makes me want to go rip my carb off and show you mine
Re: VIC 340 [Re: roadhazard] #590859
01/22/10 08:13 PM
01/22/10 08:13 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
So Vic, how thick of a spacer are you going to run with that thermoquad?...........
Re: VIC 340 [Re: SuperStocker] #590860
01/22/10 08:29 PM
01/22/10 08:29 PM
Huh?
