Page 3 of 5 1 2 3 4 5
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588620
01/24/10 02:46 PM
01/24/10 02:46 PM
Germany
fc7_plumcrazy Offline
Germany
Hi Dan,
congratulations.
Hope you will have it running soon. Liked it, too when I saw it on ebay but the non-running condition kept me away.
Carsten
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: fc7_plumcrazy] #588621
01/24/10 06:51 PM
01/24/10 06:51 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i,m sure it would have sold had anyone known it was a W23 car i was the ONLY one who really was interested and was luckily able to get him to pull the back seat and the rest is history as they say... i,m sure in a few weeks it will be drivable dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588622
01/24/10 09:43 PM
01/24/10 09:43 PM
Germany
Germany
Hi Dan,
I just liked it for what it was. It has a great colour combination. Seller had it on craigslist before several times always wrote will get it running soon but he didn't.
The W23 option is a big extra for those who appreciate it.
Currently have a 69 CHP Polara with a locked up engine so no extra need for me to buy a non-running car right now
Good luck to get it on the road soon.
Carsten
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: fc7_plumcrazy] #588623
01/25/10 04:31 AM
01/25/10 04:31 AM
NW
hergfest Online content
hergfest  Online Content
NW
Chrysler overreacted on the recall wheels. I know a guy in BC who has a 69 Barracuda that still has the original recall wheels on it and he has never had a problem. Just kept them torqued. Also, I have heard that they were sold in the 70's as an aftermarket wheel and no one had problems then either.
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: hergfest] #588624
01/25/10 11:41 AM
01/25/10 11:41 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
gary you are correct the ONLY ones that failed were the ones not retorqued and came LOOSE! dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588625
01/25/10 12:37 PM
01/25/10 12:37 PM
The New Jersey Hinterlands
Sssnake383 Offline
Old and boring
Sssnake383  Offline
Old and boring
Lookin' good. Can't wait to see this car with the recall wheels installed. What are you waiting for???
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: Sssnake383] #588626
01/25/10 12:51 PM
01/25/10 12:51 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
looking for tires now cleaning car up a little every day also my newest set of recall wheels should be here today or tomorrow hopefully dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588627
01/25/10 01:00 PM
01/25/10 01:00 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
Dan - I have been looking at the BS and I am lost where it says W23, where on it should I look.... Congrats on the car, it will look cool with the wheels back on it again....
71 GTX 4sp Dana GY9 HD Road King
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: AZ-Nick] #588628
01/25/10 01:47 PM
01/25/10 01:47 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
nick look at the bottom of the second sheet pic.. in the W section [WHL COVER] last one on the right on the bottom..you see a typed 3 and above it is the W2 [hence W23] use the attacahment i-con to open it dont try and look at it on the site.. dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588629
01/25/10 01:49 PM
01/25/10 01:49 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
nick look at the bottom of the second sheet pic.. in the W section you see a typed 3 above it is the W2 use the attacahment icon to open it dont try and look at it on the site.. dan
Got it thanks,
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: AZ-Nick] #588630
01/27/10 08:57 AM
01/27/10 08:57 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
So will this one be advertised for more or less than $45,000?
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: Fury Fan] #588631
01/27/10 11:46 AM
01/27/10 11:46 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
nope!
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588632
03/25/10 01:20 PM
03/25/10 01:20 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
pulled the gas tank and man is it rusty inside... looks like its gonna be a while longer...restoring the wheels also should be running hopefully by may [if it will run] looks to have been sitting longer than i thought.. dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588633
03/25/10 03:47 PM
03/25/10 03:47 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Dan, what's the deal with the air cleaner on that car? Do you think it's original?
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: NicksGarage] #588634
03/25/10 05:44 PM
03/25/10 05:44 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
That is the original Air cleaner my father has 69 Sport fury W/383 and that's the factory one on his an he is the original owner...
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: QuickBpBp] #588635
03/25/10 07:34 PM
03/25/10 07:34 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Does his have A/C?
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: NicksGarage] #588636
03/25/10 08:00 PM
03/25/10 08:00 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
nick yes its original! and has a/c was a one owner car until a few yrs ago and the guy i got it from did nothing to it... i thought it was a bit unusual but have seen a few since then also...early SPD 828 [last day of recall wheel availability] 68 dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588637
03/25/10 08:04 PM
03/25/10 08:04 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Thanks, I'll add that to my record for air cleaners.
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: NicksGarage] #588638
03/25/10 08:11 PM
03/25/10 08:11 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
also no pie tins! dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: NicksGarage] #588639
03/25/10 09:30 PM
03/25/10 09:30 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Does his have A/C?
Yep my dad's has A/c too and Dan is right NO pie tin....It's the same Air cleaner on some A & B bodies too...
