Page 2 of 5 1 2 3 4 5
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ChryCoGuy] #588600
01/20/10 06:51 PM
01/20/10 06:51 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i looked at the brochure and dont see any triple stripe all seem to be single white stripe... i have 5 sets of these wheels and none are cracked one set i have driven on over the last 2o yrs dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588601
01/20/10 07:02 PM
01/20/10 07:02 PM
Glen Burnie MD
68SportFury Offline
68SportFury  Offline
Glen Burnie MD
I hope you have that piece of moulding for the right quarter. '69 VIP trim is probably even more fun to hunt for than '68 Sport Fury stuff.
Paul
68 Sport Fury ragtop
67 Fury III 4-dr HT
11 Charger Rallye
17 Challenger SXT Plus
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: 68SportFury] #588602
01/20/10 07:05 PM
01/20/10 07:05 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i have it NOS they arent real hard to find it seems since i,m the ONLY 1 in the world looking for any!!! hahaha dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588603
01/21/10 11:27 AM
01/21/10 11:27 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
any other W23 full size cars out there known?
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588604
01/21/10 11:35 AM
01/21/10 11:35 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Nicely optioned car
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588605
01/21/10 11:45 AM
01/21/10 11:45 AM
Belleville Il
Dingmaster Offline
Dingmaster  Offline
Belleville Il
What does the broacast sheet say for tires?
I would expect G78x15 dual line goodyears.
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: Dingmaster] #588606
01/21/10 11:48 AM
01/21/10 11:48 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
U22 code for tires 8.25x15 WSW dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588607
01/21/10 01:56 PM
01/21/10 01:56 PM
Gig Harbor,WA
Commando66 Offline
Commando66  Offline
Gig Harbor,WA
Dan, is that a light weight? Just kidding looks in pretty good shape. Mike
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: Commando66] #588608
01/21/10 02:08 PM
01/21/10 02:08 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
mike the WHEELS are light weight!!! especially good at lightening the wallet!! hahahaha hope to get it running and cruise a bit this summer later dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588609
01/21/10 02:09 PM
01/21/10 02:09 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Plymouths look great with strobe srtipes, so why not on the tires, too?
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: In_The_Pink] #588610
01/21/10 02:42 PM
01/21/10 02:42 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
cool tire never seen that one before...
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588611
01/21/10 04:48 PM
01/21/10 04:48 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
well car is NUMBERS MATCHING! yay! always nice dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588612
01/21/10 04:48 PM
01/21/10 04:48 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
engine PP23H9D111496
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: Pat_Whalen] #588613
01/22/10 09:11 AM
01/22/10 09:11 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
you can drive on them... no problem.. when new they would come loose because no one retightened the lugs like they were supposed to...
According to the information I found, the lugnuts would work themselves loose and re-torqueing them would result in cracking the aluminum center.
no, losing the preload on the wheel studs and driving it is what causes the cracking....keep 'em tight, and you're fine
2017 Grand Cherokee Overland
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: patrick] #588614
01/22/10 11:24 AM
01/22/10 11:24 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
yep..loose lugs and alum wheels dont mix
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: Dingmaster] #588615
01/22/10 02:50 PM
01/22/10 02:50 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
What years/models did that wheel cover come on? From the green car that was posted several posts before this one.
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588616
01/22/10 03:40 PM
01/22/10 03:40 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
"loose lips sink ships"
"loose lugs sink boats"!
Dan: I want to see the car at the Seattle show or at your place this year!
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: m46rat] #588617
01/22/10 05:50 PM
01/22/10 05:50 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
dwight i will have it running in a few weeks [hopefully] and it will be making the show circuit in seattle this summer also if you are down this way always give me a call dan
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: ph23vo] #588618
01/22/10 08:15 PM
01/22/10 08:15 PM
RI Deep in the rust belt
chargervert Online content
chargervert  Online Content
Dan,hows the trunk floor in that thing? I have a clean section from a 69 New Yorker if you need it. It's cut between the frame rails,and is cut from the top curve in the front,and has the center part of the rear crossmember on the back of it. PM me if you need it.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: W23 RECALL WHEEL 69 fury VIP is home [Re: chargervert] #588619
01/23/10 06:18 PM
01/23/10 06:18 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
thanks pete!
