Re: Differences between 1968 and 69/70 Road Runner doors???
[Re: JJ300]
#588410
01/20/10 12:40 PM
01/20/10 12:40 PM
Posts: 18,167 Mass
DAYCLONA
Mass
I did it on my 69. Welded up one hole, drilled another. Linkage may need switched also.
....68 are 1 yr only as far as the lock location, and a few other items, you'll need to switch the window regulator, vent window channel as 68 glass runs/channels are different, including the 1 at the back of the door, swap over your 69-70 stuff, might have to drill a few holes on the reg install IIRC
Mike
[Re: Stanton]
#588418
01/21/10 10:40 AM
01/21/10 10:40 AM
Posts: 4,113 Horsham, Pa.
Finoke
Horsham, Pa.
Not to mention the price is RIDICULOUS.
Exactly! I just made the modifications last night. It took a half hour to save $600.
