Mallory 6AL owners: 50 degrees initial timing! #587601
01/19/10 01:47 PM
01/19/10 01:47 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
So I recently installed a new ignition system in my car, and finally (FINALLY!) got my car running again yesterday. The problem: the engine would run unless the initial timing was somewhere between 40 and 55 degrees, and even then it wouldn't run well.
The solution: switching the +/- wires that go from my Mallory 6AL ignition box to my distributor.
Evidently, Mallory's instructions have a misprint and the wiring is backwards. My Summit receipt mentioned a misprint regarding Chrysler set-ups but the notice ended abruptly after the words "should read as follows". Thanks, Summit.
Anyway, I'm just posting this in case anyone buys a MSD or Mallory ignition box and runs into a similar situation.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: 1968RR] #587602
01/19/10 02:58 PM
01/19/10 02:58 PM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
Thanks for the heads up , I will have to look at mine (havent attemted to fire yet)
where can I find a correct wiring diagram?
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: Dr-Dave2] #587603
01/19/10 03:06 PM
01/19/10 03:06 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Same thing happens with an MSD box. MSD's instructions were wrong for a long time.
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: RobX4406] #587604
01/19/10 03:27 PM
01/19/10 03:27 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Hmm, that might explain why a Mallory box i bought wouldn't work right.
What wires are wrong on the instructions?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: joedust451] #587605
01/19/10 03:30 PM
01/19/10 03:30 PM
RobX4406 Offline
RobX4406  Offline
The wiring diagram has distributor leads crossed. Whatever the instructions say, flip them and try again.
I found this out putting a MSD6AL on a car and the timing changed a bunch. Flipped the wires and it was spot on again.
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: RobX4406] #587606
01/19/10 04:30 PM
01/19/10 04:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
MSD = Might-Sputter & Die
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: DAYCLONA] #587607
01/19/10 04:46 PM
01/19/10 04:46 PM
Instructions had the wiring backwards . I bet some heads rolled over that gaff .
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: RapidRobert] #587608
01/19/10 06:00 PM
01/19/10 06:00 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
no, Instructions STILL HAVE the wiring backwards. i just went and looked. you can see on the instructions where they say to hook the + side to the Neg lead and vice verca
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: joedust451] #587609
01/19/10 06:14 PM
01/19/10 06:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That may explain why I've got a mallory box in my garage that the previous owner claimed he couldn't get to work right...
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: aarcuda] #587610
01/19/10 06:16 PM
01/19/10 06:16 PM
You'd think a proof reader woulda caught that. I cant think of any circuit type right offhand where positive goes to negative
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: RapidRobert] #587611
01/19/10 08:48 PM
01/19/10 08:48 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
So, Violet +, Green - on the dizzy??
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: joedust451] #587612
01/19/10 11:30 PM
01/19/10 11:30 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
look here http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Products/Ignitions/6420_instructions(1).pdf page says violet goes to orange
look here figure 20 http://www.malloryperformance.com/pdf/6852M_6853M.pdf says violet goes to black
look here figure 21 http://www.malloryperformance.com/pdf/1643.pdf shows violet goes to black BUT the polarities are wrong
SO, VIOLET GOES TO ORANGE (+ to +) and GREEN GOES TO BLACK (- to -)
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: 1968RR] #587613
01/20/10 12:27 AM
01/20/10 12:27 AM
San Jose, CA
Blue69Charger Offline
San Jose, CA
I bought a electronic distributor plug from the wrecking yard off a 70's van. It has a black and brown wire. I followed the mallory directions thinking the brown wire was originally orange and it worked fine. I just looked at my new accel performance replacement distributor and it looks like the wire colors on the plug are reversed. Black goes to orange and brown goes to black. Maybe the new distributors are backwards compared to the factory ones?
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: Blue69Charger] #587614
01/23/10 07:29 PM
01/23/10 07:29 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
Some aftermarket distributor pick up coils are wired wrong,and will cause the same problems with the stock ignition system.
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: bigslant6fan] #587615
01/23/10 09:49 PM
01/23/10 09:49 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have a MSD distributor and 6Al box, so does that wire switch apply to me also? My timing is like 50 plus degrees too.
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: mopars4ever] #587616
01/23/10 10:16 PM
01/23/10 10:16 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
swap em and see
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: aarcuda] #587617
01/23/10 10:50 PM
01/23/10 10:50 PM
md
mopars4ever Offline
mopars4ever  Offline
md
swap em and see
Will it hurt anything?
Re: Mallory 6AL owners: 50 degrees initial timing! [Re: mopars4ever] #587618
01/23/10 11:00 PM
01/23/10 11:00 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
no. i did it the other day. check youyr timing rheap the pickup wires. if the timing retards, then you had it wrong and it should be left swapped.
if the timing advances, then you had it right to begin with
read this https://board.moparts.org/ubbthreads/show...rue#Post5747701
