tail light ? 71 swinger #586114
01/17/10 11:00 PM
01/17/10 11:00 PM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
Does anyone know if the light bulb socket should come out of the back of the housing from a 71 dart swinger? I can see removing the lens to remove the bulb, but are these permanently attached? I'm looking to remove the sockets and pigtails to sell them but I don't wanna break them if they are supposed to be a single unit. Thanks.
Re: tail light ? 71 swinger [Re: POZEST] #586115
01/18/10 12:44 AM
01/18/10 12:44 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
remove the lense and it s/b obvious if the socket comes out.
Re: tail light ? 71 swinger [Re: POZEST] #586116
01/18/10 01:49 AM
01/18/10 01:49 AM
Sturgis S.D.
tripleblackcuda Offline
Sturgis S.D.
does the socket turn?
Re: tail light ? 71 swinger [Re: tripleblackcuda] #586117
01/18/10 03:14 AM
01/18/10 03:14 AM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
I can't get the socket to turn at all.
Re: tail light ? 71 swinger [Re: POZEST] #586118
01/18/10 07:07 PM
01/18/10 07:07 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the sockets are dual "cup" assembly inserting one inside the other and twisting like the bulb istelf, making a "sandwich" with the housing.
I don't think you'll be able to remove them without damage
I made one to reinstall one socket to another shouing, opening the inner lip ( prying ) and pressing it back once on my actual housing... not pretty but worked
Re: tail light ? 71 swinger [Re: POZEST] #586119
01/18/10 07:12 PM
01/18/10 07:12 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
The socket is not meant to come out of the housing.
Doesn't mean you can't try, but go in knowing that you might not like the results.
Down to just a blue car now.
