Hemi problems again.. valve to valve clearance
#585908
01/17/10 07:38 PM
01/17/10 07:38 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Finally got everything mocked up, short block together etc. Despite some trouble with with the rotating assembly, (actually a rod bearing issue). Well I talked with a few of some very helpful people on this board, so I decided to do some checking for possible valve to valve issue's. I measured the distance between the valves with the valves on the seat, and didnt like what i found.. Mopar calls for .280-.300 for cams above .700 lift. I had right at .255-.260 or so. So I knew this might be a problem.. Well this cam is has wide lobe centers of 112 LSA, I degree'd and checked the cam and installed it at a 109-110 ICL so its advanced a hair. Well I was checking piston to valve clearance which is fine By the way... Anyways I was checking piston to valve clearance and noticed that the valves during overlap was very close, you can see the valve events pretty good looking through the intake port..How close..Well they didnt touch rotating the engine in the correct direction. But as I rotated the engine back words, I guess the slop in the timing chain etc retarded the cam, or changed the valve events enough that the valves clipped each other...They physically hit one another.. I had those light checker springs installed etc, so I didnt bend any valves etc. Luckily.. So now, I want to run this cam, so I must address the valves/heads to correct this issue. I know I can sink the valves, Should I sink just one valve like .050 or sink them both like .025? The valves are on diff angles so maybe I can gain more by sinking one valve compared to sinking the same amount off the other? Can the valves them self's be back cut any to gain any radial clearance?? Even if I can take as little as .008-.010 off each valve diameter would help.. Thanks in advise Bob Coomer
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Hemi problems again.. valve to valve clearance
[Re: Cab_Burge]
#585910
01/17/10 08:39 PM
01/17/10 08:39 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
Before getting too excited about them hitting i would set the valves up with the intended springs you are going to use, set with lash and then check again (going the correct direction). There will be a bit of deflection in the pushrods and the rest of valvetrain, big cams are a lot of times real close on valves missing each other, but if you do have to adjust i would cut the exhaust valve down slightly.
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
[Re: Rapid588]
#585911
01/17/10 08:51 PM
01/17/10 08:51 PM
Bob_Coomer
Rock Springs
My machist actually told me the same thing.
During the time that they were hitting. There was NO head gasket, the valve lash was set to zero. I dont think the head gasket would matter, but the valve lash might make a diff. But even MP knew it might be problem with large lift and large duration cams..And Ma Mopar called for .300 between the valves with them on the seat...I know for fact I have only .255-.260 max..Si its close. If two years down the road, and I have some valve guide wear..kaboom..its too close for comfort for me really. I couldnt measure it, but at the closest point it was only .020 inch .025 tops.
[Re: Bob_Coomer]
#585916
01/17/10 11:54 PM
01/17/10 11:54 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
hey bob i run .900 lift and .260 valve to valve,,,, ma mopar must have missed the boat on me.... the mopar jury must not apply to me..
do not go on assumption.... check your actual clearance with springs, lash up through the bottom of the cylinder,, if you have .025 run it
and pretty much noone runs .300 valve to valve anymore,, unless you are running a 426 with a cam from 1970
[Re: moderncylinder]
#585917
01/18/10 07:53 AM
01/18/10 07:53 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Priceless info right there!!I would never have thought......
[Re: LSP]
#585919
01/18/10 08:57 AM
01/18/10 08:57 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Check all the valve to valve measurements on the seat on each chamber. Note the chamber with the closest measurement, pull that piston/rod out and mock up the head/actual valvetrain on that cylinder. See that you have the minimum of .025" as Jeff said at valve overlap. I would leave the intakes alone, and sink/clip the exhausts to get your clearance.
Careful about following the mopar "bible" too much, that info is way outdated.
it says the purple cam is the most powerful cam for a 440
Bob, I would listen to ModernCylinder
[Re: MuscleMike]
#585923
01/18/10 03:43 PM
01/18/10 03:43 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
With close center long duration camshafts it is advisable to have a minimum of .280/.290 between the valves on the seat.Jeff may be getting away with .025 at the valve to valve intersecting point and only have .260 between the valves on the seat with the design of cam he is using.I would not and never recommend you use his numbers with that cam I gave you.The slightest deviation could spell disaster, a loose guide,slight varaying position of a guide center,or a side loading of the valve from unstabe or poor geometry.Even a pushrod bind can cause enough deflection in a long valve with a 5/16 stem to cause concern.I'am not doubting Jeff's claim,after all he is the head guru for race applications and especially SS/AH Hemis,and he would know better than any of us.If your that confident in his recommendation go for it,what do you have to loose?I stand buy what I said,I would rather be conservative and safe than be sorry later.Bob your not building a SS/AH granade and trimming or sinking those valve won't kill a 100hp for sure and you will sleep better.What ever you decide,good luck. P.S.FYI, Jeff it is an early style cam.
[Re: Cab_Burge]
#585926
01/18/10 04:13 PM
01/18/10 04:13 PM
Posts: 2,128 sweden
sshemi
sweden
Are you saying that the int and ex valves in the same cylinder are hitting each other when you turn the motor over only in one diretion????? How the %#!" is that possible??? Is the cam twisting in one direction?
Cam does not twist, it is a physcical contact on the overlap of the valves, not unusual with bigger cams on the 426 hemi motors, be very careful when setting the cam up and make sure to check them like what has already been said to do the bigger the lift(.700+ and duration (286+)the more likely you can have a problem
But only when turning it over in one direction???
