Page 1 of 3 1 2 3
Hemi problems again.. valve to valve clearance #585908
01/17/10 07:38 PM
01/17/10 07:38 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Finally got everything mocked up, short block together etc. Despite some trouble with with the rotating assembly, (actually a rod bearing issue).
Well
I talked with a few of some very helpful people on this board, so I decided to do some checking for possible valve to valve issue's. I measured the distance between the valves with the valves on the seat, and didnt like what i found.. Mopar calls for .280-.300 for cams above .700 lift. I had right at .255-.260 or so. So I knew this might be a problem..
Well this cam is has wide lobe centers of 112 LSA, I degree'd and checked the cam and installed it at a 109-110 ICL so its advanced a hair.
Well I was checking piston to valve clearance which is fine By the way...
Anyways
I was checking piston to valve clearance and noticed that the valves during overlap was very close, you can see the valve events pretty good looking through the intake port..How close..Well they didnt touch rotating the engine in the correct direction. But as I rotated the engine back words, I guess the slop in the timing chain etc retarded the cam, or changed the valve events enough that the valves clipped each other...They physically hit one another.. I had those light checker springs installed etc, so I didnt bend any valves etc. Luckily..
So now, I want to run this cam, so I must address the valves/heads to correct this issue. I know I can sink the valves, Should I sink just one valve like .050 or sink them both like .025? The valves are on diff angles so maybe I can gain more by sinking one valve compared to sinking the same amount off the other?
Can the valves them self's be back cut any to gain any radial clearance??
Even if I can take as little as .008-.010 off each valve diameter would help..
Thanks in advise
Bob Coomer
Re: Hemi problems again.. valve to valve clearance [Re: Bob_Coomer] #585909
01/17/10 08:22 PM
01/17/10 08:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
Clipping the valves is usally better than sinking the valve seats. Are these new valves? If so maybe grinding the valves a little first may solve the problem, if there real thick at the seat
Re: Hemi problems again.. valve to valve clearance [Re: Cab_Burge] #585910
01/17/10 08:39 PM
01/17/10 08:39 PM
Boynton Beach, Fl
Rapid588 Online content
Rapid588  Online Content
Boynton Beach, Fl
Before getting too excited about them hitting i would set the valves up with the intended springs you are going to use, set with lash and then check again (going the correct direction). There will be a bit of deflection in the pushrods and the rest of valvetrain, big cams are a lot of times real close on valves missing each other, but if you do have to adjust i would cut the exhaust valve down slightly.
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Hemi problems again.. valve to valve clearance [Re: Rapid588] #585911
01/17/10 08:51 PM
01/17/10 08:51 PM
Rock Springs
Rock Springs
My machist actually told me the same thing.
During the time that they were hitting. There was NO head gasket, the valve lash was set to zero. I dont think the head gasket would matter, but the valve lash might make a diff.
But even MP knew it might be problem with large lift and large duration cams..And Ma Mopar called for .300 between the valves with them on the seat...I know for fact I have only .255-.260 max..Si its close. If two years down the road, and I have some valve guide wear..kaboom..its too close for comfort for me really.
I couldnt measure it, but at the closest point it was only .020 inch .025 tops.
Re: Hemi problems again.. valve to valve clearance [Re: Bob_Coomer] #585912
01/17/10 09:00 PM
01/17/10 09:00 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I would cut a little off each valve first,drop the seats a little second or a little of both.
Re: Hemi problems again.. valve to valve clearance [Re: B G Racing] #585913
01/17/10 09:27 PM
01/17/10 09:27 PM
Rock Springs
Rock Springs
I was hoping you would chime in Bob..
I dug out my Old MP engine book, and according to this, are you referring to cutting some off the margin?
Also I wrote down some notes you told me and some angled for cutting...
Chrysler recommends .265 for cams in the .600 lift range and .300 for cams in the .700 lift range.Cut the exhaust valve parallel to the stem and cut the intake 29 degrees to valve stem ,or sink the valves.This is what I like about the Indy Legend head with the moved exhaust valve. I would still use a steel gage,the valve can easly cut quite a few .000s into the aluminum.
Re: Hemi problems again.. valve to valve clearance [Re: Bob_Coomer] #585914
01/17/10 10:32 PM
01/17/10 10:32 PM
Boise
Moparteacher Offline
Boise
Yea..install the actual springs, set zero lash, pull your pistons and rods, leave the crank, assemble and install both heads on the block.
Now confirm actual v-v clearance with a feeler gauge up reaching through the bottom.
Re: Hemi problems again.. valve to valve clearance [Re: Moparteacher] #585915
01/17/10 10:42 PM
01/17/10 10:42 PM
Rock Springs
Rock Springs
I dont think I need too...I know they need work..The Mopar Jury has reached a decision.
If I had .280 between the valves yea..maybe...But Im almost .050 from recommended minimal valve to valve clearance LOL
Re: Hemi problems again.. valve to valve clearance [Re: Bob_Coomer] #585916
01/17/10 11:54 PM
01/17/10 11:54 PM
detroit area
moderncylinder Offline
detroit area
hey bob i run .900 lift and .260 valve to valve,,,, ma mopar must have missed the boat on me.... the mopar jury must not apply to me..
do not go on assumption.... check your actual clearance with springs, lash up through the bottom of the cylinder,, if you have .025 run it
and pretty much noone runs .300 valve to valve anymore,, unless you are running a 426 with a cam from 1970
Re: Hemi problems again.. valve to valve clearance [Re: moderncylinder] #585917
01/18/10 07:53 AM
01/18/10 07:53 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Priceless info right there!!I would never have thought......
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi problems again.. valve to valve clearance [Re: Bob_Coomer] #585918
01/18/10 08:47 AM
01/18/10 08:47 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Check all the valve to valve measurements on the seat on each chamber. Note the chamber with the closest measurement, pull that piston/rod out and mock up the head/actual valvetrain on that cylinder. See that you have the minimum of .025" as Jeff said at valve overlap. I would leave the intakes alone, and sink/clip the exhausts to get your clearance.
Careful about following the mopar "bible" too much, that info is way outdated.
Re: Hemi problems again.. valve to valve clearance [Re: LSP] #585919
01/18/10 08:57 AM
01/18/10 08:57 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
it says the purple cam is the most powerful cam for a 440
Bob, I would listen to ModernCylinder
Re: Hemi problems again.. valve to valve clearance [Re: Defbob] #585920
01/18/10 09:08 AM
01/18/10 09:08 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You can very easily check the clearence with a wire gage through the intake or exhaust port.Listen to whoever,I would look for a minimum of .035.
Re: Hemi problems again.. valve to valve clearance [Re: B G Racing] #585921
01/18/10 02:32 PM
01/18/10 02:32 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Are you saying that the int and ex valves in the same cylinder are hitting each other when you turn the motor over only in one diretion?????
How the %#!" is that possible???
Is the cam twisting in one direction?
Re: Hemi problems again.. valve to valve clearance [Re: Bob_Coomer] #585922
01/18/10 03:05 PM
01/18/10 03:05 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
FYI: odds are you will have intake pushrod clearance issues on #1 &#8. The way they machined those old Mega blocks the intake pushrods hit the block.
Mike @MM
Re: Hemi problems again.. valve to valve clearance [Re: MuscleMike] #585923
01/18/10 03:43 PM
01/18/10 03:43 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With close center long duration camshafts it is advisable to have a minimum of .280/.290 between the valves on the seat.Jeff may be getting away with .025 at the valve to valve intersecting point and only have .260 between the valves on the seat with the design of cam he is using.I would not and never recommend you use his numbers with that cam I gave you.The slightest deviation could spell disaster, a loose guide,slight varaying position of a guide center,or a side loading of the valve from unstabe or poor geometry.Even a pushrod bind can cause enough deflection in a long valve with a 5/16 stem to cause concern.I'am not doubting Jeff's claim,after all he is the head guru for race applications and especially SS/AH Hemis,and he would know better than any of us.If your that confident in his recommendation go for it,what do you have to loose?I stand buy what I said,I would rather be conservative and safe than be sorry later.Bob your not building a SS/AH granade and trimming or sinking those valve won't kill a 100hp for sure and you will sleep better.What ever you decide,good luck. P.S.FYI, Jeff it is an early style cam.
Re: Hemi problems again.. valve to valve clearance [Re: sshemi] #585924
01/18/10 03:58 PM
01/18/10 03:58 PM
Cam does not twist, it is a physcical contact on the overlap of the valves, not unusual with bigger cams on the 426 hemi motors, be very careful when setting the cam up and make sure to check them like what has already been said to do the bigger the lift(.700+ and duration (286+)the more likely you can have a problem
Re: Hemi problems again.. valve to valve clearance [Re: Bob_Coomer] #585925
01/18/10 03:59 PM
01/18/10 03:59 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Besides clipping the valves for clearance, no one mentioned(or I missed it) anywhere about cutting the exhaust valve to 1.900. I agree with BG..old school cams should be set up the old school way. I run a Crane R290 in my 477 and it's clipped with 1.900 exh valves. It wouldn't work(clear) any other way even with moving the cam timing around.
Re: Hemi problems again.. valve to valve clearance [Re: Cab_Burge] #585926
01/18/10 04:13 PM
01/18/10 04:13 PM
sweden
sshemi Offline
sshemi  Offline
sweden
But only when turning it over in one direction???
Re: Hemi problems again.. valve to valve clearance [Re: Cab_Burge] #585927
01/18/10 04:16 PM
01/18/10 04:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Good luck with it but if it were me I would mock it up as it is going to be run, lash, springs and all. Then see what you get. BTW the comment about the block and pushrod clearance is spot on, it is gonna need some grinding, even my World block needed a little with an appropriately sized pushrod.
Page 1 of 3 1 2 3
