what spark plug? #585089
01/17/10 08:00 AM
01/17/10 08:00 AM
virginia
tigger1 Offline OP
tigger1  Offline OP
virginia
Wondering which number to use. I prefer to use NGK's as I have had great service through the years. I am planning on switching from 63 max wedge heads to Victors or Procomps. 496,12-1, 600@260,strip only. Wondering what heat range to start with?
Twin turbo 440 72 barracuda
Re: what spark plug? [Re: tigger1] #585090
01/17/10 08:46 AM
01/17/10 08:46 AM
dome or flat top pistons?
5671A-8 for dome non projected tip
for dome.
5672A-8 for flat top projected tip
NGK spark plug.
Re: what spark plug? #585091
01/17/10 08:51 AM
01/17/10 08:51 AM
virginia
tigger1 Offline OP
tigger1  Offline OP
virginia
Ross flat top. Thanks for the information. I did not want to guess and carbon every thing up or worse trying to learn every thing the hard way.
Re: what spark plug? [Re: tigger1] #585092
01/17/10 09:10 AM
01/17/10 09:10 AM
no problem, just remember these are for alumuinum heads.
Re: what spark plug? #585093
01/17/10 10:36 AM
01/17/10 10:36 AM
NC
440Jim Offline
440Jim  Offline
NC
NGK spark plug.
That is a good starting point. R5672A-8 (#7173)
But you likely could run a step hotter. A street plug would be BCP7ES (#5030). I ran them at 12.2 CR, but make sure your mixture isn't lean.
Re: what spark plug? [Re: tigger1] #585094
01/17/10 11:02 AM
01/17/10 11:02 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
thanks for posting about this plugr5671a-8[list# 4554] it is listed for the B1 bs head.i was just researching it.
