Re: intake manifold for 440
[Re: TX91971]
#580017
01/11/10 11:12 PM
01/11/10 11:12 PM
Posts: 5,620 long island NY
Ari440
long island NY
72 duster
3470 pound car 4200 stall 4.56 30-10.5 slicks
446 ci 12.5 613/276 stage 4 ported heads
M1 two inch spacer 850 11.20s
put a 1050 with a two inch adapter 11.00s
1.39 9.85 - 137 mph
[Re: moparguy7074]
#580021
01/11/10 11:54 PM
01/11/10 11:54 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
There are a few good ones and from what I have seen the M1 , Eddy RPM or the Holley Street Dominator all seem to work about the same. I run the Street Dominator on the .030 over 440 in my 63 street /strip car. I run 10.0 comp and 906 heads with the MP .557 cam and the SD with an 850 DP. At just over 3700 lbs it has run a best of 11.49 @ 116 and thats driving to the track and racing the same as I drive it thru the pipes. I like the SD alot as my car 60 ft's ok for what it is with stock suspension and just SS springs as my best 60 ft is a 1.57 which I guess is on par for a mid 11 car. The Eddy RPM also works very good on my sons 400 Dart that runs Eddy RPM heads and the MP .557 cam and he has run 11.40's also. I have not ran the M1 myself but my brother has and many people I know and they have all ran good #'s with it for the combo's. Ron
[Re: mark7171]
#580023
01/12/10 12:42 AM
01/12/10 12:42 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Mill a Rpm manifold 1/4" for hood clearance sake. Thats your "beast" for a heavier car.
I run an rpm, and like it. for that matter, I only needed a drop base air cleaner to make it work when I ran the flat hood.
The original poster has more cam and gear though, so I think a single plane MAY be a better pick. Copuld go either way
As for a holley, 950hp holley would be about right.
[Re: dodgeboy11]
#580027
01/12/10 10:32 AM
01/12/10 10:32 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Though I'd stay away from the original torker lol, or the weiand xcelerator. That sharp turn where the manifold hits the head isn't a great idea for the fuel keeping itself suspended.
I have a #7512 X-Celerator on mine
At this point it's starting to hold me back and needs some more massaging or a new Victor
[Re: 440Jim]
#580029
01/12/10 01:21 PM
01/12/10 01:21 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I agree...If you ever plan on stepping up in the HP department down the road, get one that will support good power later, so your not buying another intake...The Edelbrock Victor would be my choices.. This intake is capable of making 750-800hp...The RPM would be my last choice cause of design, even though it my perform just as good now.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 440Jim]
#580030
01/12/10 09:42 PM
01/12/10 09:42 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
Not exactly your combo, but for comparison:
I have that article somewhere. Pretty impressive performance with the Street Dominator. IIRC, Dulcich said that particular intake had some very minor blending done in the plenum. The Team G had a core shift problem, which i have heard is not uncommon with that intake.
[Re: forphorty]
#580031
01/12/10 10:25 PM
01/12/10 10:25 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Interesting to see the Torker II out perform the Performer RPM in that test.I always thought that intake was the "also ran" intake when compared to the SD or the RPM Those intakes can be had pretty cheap Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Cab_Burge]
#580034
01/13/10 02:41 PM
01/13/10 02:41 PM
Posts: 3,152 Central NC
gch
Central NC
The sreet dominator with a 1" or 2" spacer(I ran mine with a 1" tapered 4 hole on top of a 1" open) would work well. With a heavier car maybe a dual plane like the Indy 440-2d would work as well.Streetwize has gotten great results with one.
