Page 3 of 5 1 2 3 4 5
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574364
01/08/10 08:36 AM
01/08/10 08:36 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Ok here we go turbos are not cheap they are a nitemare to plum the headers alone are 2000 dollars if you do them right!And no you cant make big power without good parts! It takes big RPM to get turbos to make boost and you are not going to do this with stock rods and pistons.If you do it wont live long so dollar for dollar a good n/a over a stock bottom end turbo motor makes good sence for someone wanting to race or go fast on a budget!!
Not true...at all actually, it takes very a very manageable rpm to make boost with a properly sized turbo. I have see 1000k hp numbers at around 6000 rpm numerous times. We plan on making around 1300 at 6500 rpm. I dont think there is a small block on the planet doing that, regardless of cid
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574365
01/08/10 10:53 AM
01/08/10 10:53 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
it surprises me that with a screen name like yours you would post something like this that is 100% false. no naturally aspirated engine will develop the torque a turbocharged one will at lower rpm. it doesn't take rpm to make a turbo run it takes hot exhaust gases and they can be had at lower rpm. it's all a matter of having the turbo properly matched to the engine. the real problem with stock rods and pistons would be handling the increased HP a turbo will make not necessarily the rpm.
Re: any a-body turbo pictures? [Re: topfueldart] #574366
01/08/10 11:37 AM
01/08/10 11:37 AM
Edmonton alberta Canada
mr. 63plymouth Offline
yeh untill that 550dollar motor that runs mid 8's blows up and hurts the car and maybe other people,that impressive!!!!!!!!!!!! Good turbo cars SPEND money!!!!!!!!!
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574367
01/08/10 12:27 PM
01/08/10 12:27 PM
OHIO,CIRCLEVILLE
68DARTTURBO Offline
68DARTTURBO  Offline
OHIO,CIRCLEVILLE
Dont know what planet you guys are from but i build turbo cars as well as procharged cars and you dont take junk yard short blocks and go 8 nothing!!And yes it does cost 2000 to do a set of headers the right way.If you like your cars rough weld it yourself buy a kit from somewere and mig it up and look like sh.....t yea they dont cost 2000! But if you do it right TIG them measure air flow to make max power max boost then you will spend the money. And as far as making 13# of boost and only going 11,50s ill fix that for ya sometime just let me know ill find the loss of power for ya!! I have got cars only making 10#s of boost running 10,00s oh and they dont have junk yard parts!BET this anytime anyone on here wants to meet me at any track for a grude race with a boosted car that they built you got me,Ill be there with my money in hand and a car i built street car or race car!!! MOPARS RULE just to many old .school guys that wont try anything new
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574368
01/08/10 12:39 PM
01/08/10 12:39 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
has any1 comeup with a header kit yet[pre made]?
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574369
01/08/10 01:17 PM
01/08/10 01:17 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
11's from a stock slant 6 shifting at 4500rpm ain't so bad. No RPM and good longevity. Prolly less than 5k into the car. Most expensive items in that amount were the car and the turbo.
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574370
01/08/10 01:32 PM
01/08/10 01:32 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
You should read his quote before firing off...he said "There are 550 dollar turbos on 360" motors running mid 8's on 10 inch tires....
He did not say the engine was 550 dollars
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574371
01/08/10 01:33 PM
01/08/10 01:33 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Well instead of running your dummy about someone else's car you built with their money, how about you put up YOUR car for that same race and maybe you will have a few takers...
Re: any a-body turbo pictures? [Re: joshking440] #574372
01/08/10 01:59 PM
01/08/10 01:59 PM
OHIO,CIRCLEVILLE
68DARTTURBO Offline
68DARTTURBO  Offline
OHIO,CIRCLEVILLE
Well my dummy says it is my car would not race someone elses car! And i was only replying to what was said! I would love to share what i know about turbos and prochargers so the mopar family could grow like the rest of the racing world has on this subject!!! Not looking for work have too much now but would love to spread what i know.Or what i dont know i could always learn more myself!! Things i do know is that Mopar small blocks love a procharger and make good power between 5800-7000 RPM very simple set ups w/out all that header problems!! Im here so ask what you want ill tell what i know.What i do know is it is the way to make loads of power that is dependable just add gas and go!
Re: any a-body turbo pictures? [Re: joshking440] #574373
01/08/10 02:30 PM
01/08/10 02:30 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I fit two in my A-body.
Turbo cars have more personality than NA cars . As far as the power issue,nothing drives by a turbo car on the top end.
Gary White drives the Titan Motorsports Scion in the Extreme 10.5 class with the ADRL, and currently holds the class record with a 4.10 @ 174.92 Thats with a 186 CID engine and a single 91mm turbo.
Thats why my car with turbos has to weigh almost 1000 pounds more that a 850 CID NA car to race in heads up competition.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: any a-body turbo pictures? [Re: go green] #574374
01/08/10 02:55 PM
01/08/10 02:55 PM
OHIO,CIRCLEVILLE
68DARTTURBO Offline
68DARTTURBO  Offline
OHIO,CIRCLEVILLE
Hey go green let these guys know how much your headers and turbo pluming was,Did you get your stainless headers and tubing for about what 650 bucks hahahahah that cost big bucks!! Lets put a price to it if you dont mind me asking!!
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574375
01/08/10 04:08 PM
01/08/10 04:08 PM
go green Offline
go green  Offline
I used 7 2.375 180 bends that was 550 from SPD exhaust.
I used 7 2.25 J bends from Vibrant 600.
3/8 stainless flanges are 100
I was supplied the collectors ( Dynatek ) they were probably at least 500.
This is for a Pro mod with Nitrous I just finished.You still have to weld and fit
Pro custom headers are expensive and it doesn't cost much more if any , to plumb to a collector or a turbo flange. You just have the added expense of the discharge tube , charge tube , waste gates, BOV, fuel system etc. Oh ya that stuff starts to add up. Turbo SYSTEMS cost money more parts = more money.
If you could bolt on a set of $600 headers on this car if you could would you?
Re: any a-body turbo pictures? [Re: go green] #574376
01/08/10 05:14 PM
01/08/10 05:14 PM
OHIO,CIRCLEVILLE
68DARTTURBO Offline
68DARTTURBO  Offline
OHIO,CIRCLEVILLE
I was just asking because eveyone seems to think you just slap a turbo on a motor and go racing and go fast!! There is alot of fab work that is done to do this, So when i say 2000 dollars to hang a turbo i am not talking out my but!!! thanks for the reply buy the way is that your work in the pics if so NICE!!!
Re: any a-body turbo pictures? [Re: go green] #574377
01/08/10 05:17 PM
01/08/10 05:17 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Green....check this place out for your bends....I bought my stuff from them, and its great quality and fast shipping. I can get all those bends you mentioned that you used for about 600 dollars.
www.mandrel-bends.com
Re: any a-body turbo pictures? [Re: joshking440] #574378
01/08/10 05:23 PM
01/08/10 05:23 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
68dartturbo, throw up a few pics of your cars, i would love to see some more forced induction mopars
Re: any a-body turbo pictures? [Re: joshking440] #574379
01/08/10 05:55 PM
01/08/10 05:55 PM
OHIO,CIRCLEVILLE
68DARTTURBO Offline
68DARTTURBO  Offline
OHIO,CIRCLEVILLE
Ill try
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574380
01/08/10 08:23 PM
01/08/10 08:23 PM
IL
knyech1 Offline
knyech1  Offline
IL
I kind of agree with this. All I ever seem to see are mustangs and chevys with turbos that make real good horsepower. Don't see many mopars with turbos. It does seem to be the new thing for power. I am an NA guy kinda but still I love seeing turbo cars at the track, it's "techie" it's cool it's different and it's FAST!!!
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574381
01/08/10 08:51 PM
01/08/10 08:51 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Dude, nothing I do would ever impress you, cuz you obviously think your the greatest around. Boost is a measure of restriction, you should know that my stock junk head, stock exhaust manifold setup will take boost to make power. Send me some money and I'll change the top end and make plenty of horsepower to run 9's on 10 lbs.
My car is one part from 10's. A topend from 9's, but it doesn't matter what I do to you, you just wanna talk smack.
I built this kit to show Mopar guys how easy it was to make power with nothing special, cheap parts. Not everyone NEEDS $2000 dollar headers. Go Green is basically one of one in Mopar world. I'd love to have the stuff he does, but I don't have that kind of money, and most don't.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: any a-body turbo pictures? [Re: knyech1] #574382
01/08/10 08:59 PM
01/08/10 08:59 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I looked into the turbo thing for my /6 swinger. I got as far as grabbing an old KKK turbo off a volvo- a little too small for fast spooling was the thought. Admittedly, a very mild application! Anyway, the showstopper for me was fuel delivery. The fabrication is nothing but something to do, and the necessary componants aren't too much money when you can get 4cyl import equipment used. I was just afraid of the learning curve of tuning for street use.
I could have made a hat for the carb and boost referenced the power valves, got a wastegate and blowoff valve and I already had a wideband o2 and boost/vac. guage, but it seemed like the compromises for carburated drivability were pretty huge?
All the really fast guys with turbos seem to be doing aftermarket EFI with lots of laptop tuning.
Personally I wanna break into the 12's so I'm no expert or competitive racer, just sayin'...
On the other hand, to make a track only car with 'cheap' stuff for a regular hobbyist, maybe 6-800hp is much easier with a turbo?
Not everybody needs 1200 HP!
I'd like to give it a try if I hit the lotto though...
Re: any a-body turbo pictures? [Re: radar] #574383
01/08/10 09:03 PM
01/08/10 09:03 PM
ELYRIA,OH
ELYRIA,OH
a draw thru setup can do wonders as a basic turbo setup.
