will this K-frame work?? #574245
01/05/10 09:00 PM
01/05/10 09:00 PM
nebraska
69coronet440 Offline OP
nebraska
I have a 72 duster slant six I want to convert to a V-8. I have a 67 dart V-8 K- frame I was woundering if this will fit. THANKS!
Re: will this K-frame work?? [Re: 69coronet440] #574246
01/05/10 09:07 PM
01/05/10 09:07 PM
SW FL
dodgedartgt Offline
dodgedartgt  Offline
SW FL
It will fit, but you probably do noit want it for one or two reasons.
First, it has the biscuit style engine mounts, rather than the captured spool type mounts. Okay, just use biscuits with an interlocking tab, like from Schumacher, oir later pickup trucks.
Secondly, and more important, the idler arm is of the older variety (and expensive) that is mounted on a stud. In '68, Mother started using a through bolted idler arm, so it is mounted in double shear. You won't have the flexing (or at least not as much) as in the earlier steering.
You could cut the idler mount bracket off the newer K-frame, build a jig to hold it in proper position and mate it to the '67 K-frame. Otherwise, the swap will work fine.
Mikey Bynum
Re: will this K-frame work?? [Re: 69coronet440] #574247
01/05/10 09:09 PM
01/05/10 09:09 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I think it will work, but the 67 has a unique idler arm. The 68 up untill the spool mount type k's all interchange to the best of my knowledge.
Re: will this K-frame work?? [Re: HEMIDOG 70] #574248
01/05/10 09:16 PM
01/05/10 09:16 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Like said above, it will work but it is not advised. A-Body small block k-frames are cheap. Schumacher mounts will work just fine also, though more expensive than a regular A-Body k-frame. You will need to upgrade the brakes also.
JB Rhinehart, Realist
A-Body's RULE!
Re: will this K-frame work?? [Re: 69coronet440] #574249
01/05/10 09:18 PM
01/05/10 09:18 PM
nebraska
nebraska
Thanks for the info. I will look for a newer year. THANKS again!
