What are your favorite (important) gauges - besides #571240
01/03/10 03:48 PM
01/03/10 03:48 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
What is your most important guages
assuming voltage oil pressure and Tach are already done
or what gauge was more valuable to you than you thought
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: What are your favorite (important) guages - besides [Re: Kam*Kuda] #571241
01/03/10 03:50 PM
01/03/10 03:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Since I drive my dart w/an 8" vert, I like a trans temp gauge also. Re read post duh.........definately a water temp also!
Re: What are your favorite (important) guages - besides [Re: Kam*Kuda] #571242
01/03/10 03:50 PM
01/03/10 03:50 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Other then a shift light, oil pressure gauge, and water temp, the rest is all clutter. ONLY thing I would think useful to a auto trans user would be a trans temp gauge.
Jeff
69 GTX 68 Road Runner
Re: What are your favorite (important) guages - besides [Re: Thumperdart] #571243
01/03/10 03:51 PM
01/03/10 03:51 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Im a big fan of oil temp, but we run aluminum rods...
Re: What are your favorite (important) guages - besides [Re: Kam*Kuda] #571244
01/03/10 03:52 PM
01/03/10 03:52 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I also have a water temp guage in mine.
However, After the dyno sesion and talks W/ Scott I'm looking at oil temp guages.
Re: What are your favorite (important) guages - besides [Re: WILD BILL] #571245
01/03/10 04:01 PM
01/03/10 04:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the normal stuff, shift light, oil pressure,
volts, water temp, fuel pressure and also have a
crank case pressure/vac... It depends on what I want
to look at AND if I have my data logger hooked up( I
dont have the crank case hooked up to the logger)
oh yeah.. forgot the tach... but I dont watch that,
its just a source to turn on the shift light and to
set the carb
Post deleted by Defbob [Re: WILD BILL] #571246
01/03/10 04:04 PM
01/03/10 04:04 PM
Re: What are your favorite (important) guages - besides #571247
01/03/10 04:06 PM
01/03/10 04:06 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
oil pressure,oil temp ,water temp,trans temp,fuel pressure, vacuum,
Crank case vacuum or manifold vacuum?
Re: What are your favorite (important) guages - besides [Re: Kam*Kuda] #571248
01/03/10 04:33 PM
01/03/10 04:33 PM
NC
440Jim Offline
440Jim  Offline
NC
Add to that the water temp. I use it to be consistant run and run.
I also like my trans fluid temp gauge. The engine oil temp gauge is added info and I can see the ET change with oil temp, but that is the last of the above gauges since I can estimate the oil temp effect on ET if I start going round-robin (10-15 minutes between runs in later rounds of elimination). I actually use the same gauge for both oil temps, I have a switch to change from engine oil sensor to trans sensor.
I had a fuel pressure gauge when I ran a carb. But now with the injection the pressure is roughly 80+ psi and my old gauge only went to about 15.
Some are only used for trouble shooting. Some in the staging lanes or starting line, some a glance at the finish line, and some for the return road. I have a shift light, so I don't look at the tach to shift, but during time trials I will look at it at the finish line and check oil pressure, trans temp, etc.
Re: What are your favorite (important) guages - besides [Re: Kam*Kuda] #571249
01/03/10 04:46 PM
01/03/10 04:46 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I need to add oil & trans temp gauges,,,,,,,,,,,,somewhere
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What are your favorite (important) guages - besides [Re: Kam*Kuda] #571250
01/03/10 07:13 PM
01/03/10 07:13 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
oil temp...trans temp...vacuum gauge...water temp...oil pressure...air pressure...shift light...fuel pressure
Re: What are your favorite (important) guages - besides [Re: smokinwoody] #571251
01/03/10 07:28 PM
01/03/10 07:28 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I like the dual purpose oil temp gauge idea.
I have a 5" tach and speedometer. I never look at either one. Voltmeter only when I am having trouble. Oil pressure Water temp are two biggies. When I ran nitrous I ran a pressure gauge for that and learned to only worry about it when pressure was too high(Nitrous temp is better to tune with) The single most overlooked gauge that I am glad to now have is the crankcase vacuum gauge.
Re: What are your favorite (important) guages - besides [Re: smokinwoody] #571252
01/03/10 07:30 PM
01/03/10 07:30 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I ordered you one of these,,,very hard to find,,,only available in Canada,,,LOL
Formal Sponser of Alexander Keith's Racing / Drinking Team
Re: What are your favorite (important) guages - besides [Re: 69CHARGERMD] #571253
01/03/10 08:04 PM
01/03/10 08:04 PM
sg66mopar Offline
sg66mopar  Offline
My trans Guru buddy talked me into putting in a transmission line pressure gauge late this season. I wouldn't be without one now, even after running the same car for 20 years with only oil pressure and water temp!
Re: What are your favorite (important) guages - besides [Re: sg66mopar] #571254
01/03/10 08:18 PM
01/03/10 08:18 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Oil Pres. , Engine Temp , Fuel Pressure , RPM`S in that order
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: What are your favorite (important) guages - besides [Re: sg66mopar] #571255
01/04/10 12:17 PM
01/04/10 12:17 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Why wouldn't you run without one now? What has it done for you?
Re: What are your favorite (important) guages - besides [Re: dizuster] #571256
01/04/10 12:55 PM
01/04/10 12:55 PM
sg66mopar Offline
sg66mopar  Offline
The line pressure gauge allows me to monitor what's going on in the trans. The pressure fluctuates with gear changes, rpm, etc. Just like watching the oil pressure in your motor. If you see a little blip you know there's a problem and probably even where and what it is. If the line pressure dips at a point where it shouldn't I know I'm gonna have a problem. Maybe burn the low gear band or high gear clutches, whatever.
Re: What are your favorite (important) guages - besides [Re: sg66mopar] #571257
01/04/10 02:03 PM
01/04/10 02:03 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I've thought about installing an oil temp gauge but have figured out I can tell an approx temperature by just looking at the oil pressure..
When the temp is cold, I'll have 60 psi at idle, when its up to proper operating temp, it will be at 30 psi at idle.. anything below 30 psi and I know I have trouble..
So in my humble opinion the oil temp gauge is not really that important, but would love to here the reasons why I am wrong..
Re: What are your favorite (important) guages - besides [Re: Jeepmon] #571258
01/04/10 08:29 PM
01/04/10 08:29 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thanks for the input.
The tranny gauge is an important addition as well as a booost gauge
1654.5 Mustang
1955 Land Rover
Re: What are your favorite (important) guages - besides [Re: Kam*Kuda] #571259
01/04/10 09:19 PM
01/04/10 09:19 PM
michigan
tonycpe Offline
tonycpe  Offline
michigan
wow , no one has a air / fuel ratio gauge ?
Old Fogey Racing Ltd.
