What are your favorite (important) gauges - besides
#571240
01/03/10 03:48 PM
01/03/10 03:48 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
What is your most important guages assuming voltage oil pressure and Tach are already done or what gauge was more valuable to you than you thought
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: What are your favorite (important) guages - besides
[Re: Kam*Kuda]
#571241
01/03/10 03:50 PM
01/03/10 03:50 PM
Thumperdart
State of confusion
Since I drive my dart w/an 8" vert, I like a trans temp gauge also. Re read post duh.........definately a water temp also!
[Re: Kam*Kuda]
#571242
01/03/10 03:50 PM
01/03/10 03:50 PM
Posts: 10,051 MN
JERICOGTX
MN
Other then a shift light, oil pressure gauge, and water temp, the rest is all clutter. ONLY thing I would think useful to a auto trans user would be a trans temp gauge.
Jeff
69 GTX
68 Road Runner
[Re: Kam*Kuda]
#571244
01/03/10 03:52 PM
01/03/10 03:52 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I also have a water temp guage in mine.
However, After the dyno sesion and talks W/ Scott I'm looking at oil temp guages.
[Re: WILD BILL]
#571245
01/03/10 04:01 PM
01/03/10 04:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have the normal stuff, shift light, oil pressure, volts, water temp, fuel pressure and also have a crank case pressure/vac... It depends on what I want to look at AND if I have my data logger hooked up( I dont have the crank case hooked up to the logger) oh yeah.. forgot the tach... but I dont watch that, its just a source to turn on the shift light and to set the carb
Post deleted by Defbob
[Re: WILD BILL]
#571246
01/03/10 04:04 PM
01/03/10 04:04 PM
#571247
01/03/10 04:06 PM
01/03/10 04:06 PM
WILD BILL
BROOK PARK, OH
oil pressure,oil temp ,water temp,trans temp,fuel pressure, vacuum,
Crank case vacuum or manifold vacuum?
[Re: Kam*Kuda]
#571248
01/03/10 04:33 PM
01/03/10 04:33 PM
Posts: 16,934 NC
440Jim
NC
Add to that the water temp. I use it to be consistant run and run.
I also like my trans fluid temp gauge. The engine oil temp gauge is added info and I can see the ET change with oil temp, but that is the last of the above gauges since I can estimate the oil temp effect on ET if I start going round-robin (10-15 minutes between runs in later rounds of elimination). I actually use the same gauge for both oil temps, I have a switch to change from engine oil sensor to trans sensor.
I had a fuel pressure gauge when I ran a carb. But now with the injection the pressure is roughly 80+ psi and my old gauge only went to about 15.
Some are only used for trouble shooting. Some in the staging lanes or starting line, some a glance at the finish line, and some for the return road. I have a shift light, so I don't look at the tach to shift, but during time trials I will look at it at the finish line and check oil pressure, trans temp, etc.
[Re: Kam*Kuda]
#571249
01/03/10 04:46 PM
01/03/10 04:46 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I need to add oil & trans temp gauges,,,,,,,,,,,,somewhere
[Re: smokinwoody]
#571251
01/03/10 07:28 PM
01/03/10 07:28 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I like the dual purpose oil temp gauge idea.
I have a 5" tach and speedometer. I never look at either one. Voltmeter only when I am having trouble. Oil pressure Water temp are two biggies. When I ran nitrous I ran a pressure gauge for that and learned to only worry about it when pressure was too high(Nitrous temp is better to tune with) The single most overlooked gauge that I am glad to now have is the crankcase vacuum gauge.
[Re: smokinwoody]
#571252
01/03/10 07:30 PM
01/03/10 07:30 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I ordered you one of these,,,very hard to find,,,only available in Canada,,,LOL Formal Sponser of Alexander Keith's Racing / Drinking Team
[Re: sg66mopar]
#571254
01/03/10 08:18 PM
01/03/10 08:18 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Oil Pres. , Engine Temp , Fuel Pressure , RPM`S in that order Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: sg66mopar]
#571255
01/04/10 12:17 PM
01/04/10 12:17 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
My trans Guru buddy talked me into putting in a transmission line pressure gauge late this season. I wouldn't be without one now, even after running the same car for 20 years with only oil pressure and water temp!
Why wouldn't you run without one now? What has it done for you?
[Re: Kam*Kuda]
#571259
01/04/10 09:19 PM
01/04/10 09:19 PM
Posts: 146 michigan
tonycpe
michigan
wow , no one has a air / fuel ratio gauge ?
Old Fogey Racing Ltd.
