Door Latch resto. #569828
01/02/10 01:00 PM
01/02/10 01:00 PM
Katy, TX
Bakaruda Offline OP
Bakaruda  Offline OP
Katy, TX
I need to get my door, trunk, and hood latches retored. I am asking who and where?
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
Re: Door Latch resto. [Re: Bakaruda] #569829
01/02/10 01:01 PM
01/02/10 01:01 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Wasn't Jules ('da wiperman) doing those?
Re: Door Latch resto. [Re: OzHemi] #569830
01/02/10 01:04 PM
01/02/10 01:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes. Over the top, super correct details... Call Jules!!
450-656-5438
http://www.julesdaddio.com/
Jules DAddio
5279 Gaetan Boucher
St.Hubert , Quebec
J3Y 2P8
Re: Door Latch resto. [Re: 1_WILD_RT] #569831
01/02/10 01:04 PM
01/02/10 01:04 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Thought so.
Re: Door Latch resto. [Re: OzHemi] #569832
01/02/10 06:09 PM
01/02/10 06:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Eric Manuel, username 3404, also does excellent work and is quite reasonable. Did the plating on my last 2 projects, and I'll use him again on the next one.
Re: Door Latch resto. [Re: topside] #569833
01/02/10 06:46 PM
01/02/10 06:46 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Email sent.
Thanks guys.
Completely dismantled, plated in correct finishes and then assembled with new rivets and washers.
OE caliber.
Jules
Re: Door Latch resto. [Re: JulesdaWiperman] #569834
01/02/10 11:01 PM
01/02/10 11:01 PM
Katy, TX
Bakaruda Offline OP
Bakaruda  Offline OP
Katy, TX
I recieved your email. Thank I will reply and see what we can do.
Re: Door Latch resto. [Re: Bakaruda] #569835
01/02/10 11:04 PM
01/02/10 11:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Jules is getting my Duster stuff
Re: Door Latch resto. [Re: ScottSmith_Harms] #569836
01/03/10 12:41 AM
01/03/10 12:41 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Eric, Did a beautiful job on my e-body door latches and misc
logan426
Re: Door Latch resto. [Re: MLR426] #569837
01/03/10 03:00 AM
01/03/10 03:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Depends on what level your looking for Eric will replate the assembled part so the whole part is subjected to the same plating which is a huge step up from the typical spray bomb job... But Jules takes the latch apart & replate each component with the proper finish providing a true OE type part...
Re: Door Latch resto. [Re: 1_WILD_RT] #569838
01/03/10 09:21 AM
01/03/10 09:21 AM
super gas
super gas
Another advantage is that I can lubricate the internals directly where need be with the correct yellow grease
instead of trying to inject lube.
Jules
Re: Door Latch resto. [Re: JulesdaWiperman] #569839
01/03/10 10:32 AM
01/03/10 10:32 AM
sixbbl69 Offline
sixbbl69  Offline
depends on if you want the factory look or very over restored look?these pieces are easy to detail yourself.
Re: Door Latch resto. [Re: 1_WILD_RT] #569840
01/03/10 11:54 AM
01/03/10 11:54 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I'm speaking of door latches...Jules takes door latches apart ?? Door latch is the subject.
logan426
Re: Door Latch resto. [Re: Bakaruda] #569841
01/03/10 12:55 PM
01/03/10 12:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Original post
Really??
Re: Door Latch resto. [Re: 1_WILD_RT] #569842
01/03/10 01:34 PM
01/03/10 01:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There's no such thing as "Over Restored", there's correctly restored and there's incorrectly restored, Jules hit's the "Correctly Restored" target closer than anything else I've seen.
Easy to detail yourself? Maybe if they are just dirty, but if the plating is bad or they are worn it's not a job for the average home DIY guy.
Now, let's see an example your work
Re: Door Latch resto. [Re: ScottSmith_Harms] #569843
01/03/10 05:11 PM
01/03/10 05:11 PM
Katy, TX
Bakaruda Offline OP
Bakaruda  Offline OP
Katy, TX
I spoke with Jules today. I like what we agreed to. Thanks to all for the help.
Re: Door Latch resto. [Re: Bakaruda] #569844
01/03/10 05:39 PM
01/03/10 05:39 PM
super gas
super gas
Nice speaking with you Cary.You have a super cool project in your hands.
Inner door mechanisms are loaded with rivets and springs.
The cost to do them from scratch would be too high.
Too small a market to go into.
Jules
Re: Door Latch resto. [Re: 1_WILD_RT] #569845
01/03/10 08:51 PM
01/03/10 08:51 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Original post
Really??
What kind of remark is that ??
logan426
Re: Door Latch resto. [Re: MLR426] #569846
01/04/10 02:07 AM
01/04/10 02:07 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Original post
Really??
logan426
Meaning no disrespect but the earlier part of the thread was refering to hood trunk & door latches which Jules was suggested for then a discussion of accuracy came about then you posted that the subject is door latches which now that you've edited your post to clarify that your intrest is in door latches thats cool but the thread originally was about more than door latches..And that is what I was pointing out... I didn't mean to offend but I probably am again... I seem to have knack lately... So let's & let it go..
Re: Door Latch resto. [Re: 1_WILD_RT] #569847
01/04/10 08:28 AM
01/04/10 08:28 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Original post
Really??
logan426
Ok but I have to do this before I let it go
logan426
