Edelbrock Magnum Heads *DELETED* #569050
01/01/10 08:39 PM
01/01/10 08:39 PM
La Fontaine IN
Brian Finney Offline OP
La Fontaine IN
Post deleted by Brian Finney
Re: Edelbrock Magnum Heads [Re: Brian Finney] #569051
01/01/10 09:00 PM
01/01/10 09:00 PM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
The cam's going to need a specified seat and open pressure. As long as you have .050 before coil bind and you have .050 clearance to the valve guide seal also, lift is irrelevant. Find out the recommended seat and open pressure need for the cam's lobe profiles if you are not sure.
Re: Edelbrock Magnum Heads [Re: Intense RT Dan] #569052
01/01/10 09:16 PM
01/01/10 09:16 PM
La Fontaine IN
La Fontaine IN
I was more interested in how well they hold up.
Re: Edelbrock Magnum Heads [Re: Brian Finney] #569053
01/01/10 10:08 PM
01/01/10 10:08 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
how big is the cam....
and if the eddy springs dont have enough seat pressure ...they wont hold up at all.
Tony
70 AARCuda Vitamin C
