how to get the trunk open ? tumbler turns but no open #566670
12/30/09 07:56 AM
12/30/09 07:56 AM
NY NY
3
340duster340 Offline OP
NY NY
i have reason to believe that the trunk lock is not connected properly to the latch as the key turns, but the lid still does not open.
and tips on how to get this open?
i cant crawl through the back seat because the car is tubbed / caged and pretty much no room to fit.
thanks in advance
Re: how to get the trunk open ? tumbler turns but no open [Re: 340duster340] #566671
12/30/09 08:53 AM
12/30/09 08:53 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i have had good luck getting stuck trunk lids open by using the proper socket on A LOT of extensions, 3 or 4 feet worth, and unbolting the latch from the trunk lid from the back seat.
perception is 90% of reality
Re: how to get the trunk open ? tumbler turns but no open [Re: Mr T2U] #566672
12/30/09 09:06 AM
12/30/09 09:06 AM
NY NY
3
NY NY
brilliant! trying that later today THANKS
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: how to get the trunk open ? tumbler turns but no open [Re: 340duster340] #566673
12/30/09 09:12 AM
12/30/09 09:12 AM
Mr T2U Offline
Mr T2U  Offline
make sure you have good lighting and a pick up magnet if you drop something.
Re: how to get the trunk open ? tumbler turns but no open [Re: Mr T2U] #566674
12/30/09 09:34 AM
12/30/09 09:34 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i would also tape extensions together ask me why
Re: how to get the trunk open ? tumbler turns but no open [Re: meepmeep70] #566675
12/30/09 09:39 AM
12/30/09 09:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
couldn't you just drill the old one out?
Coming soon!!!!
Re: how to get the trunk open ? tumbler turns but no open [Re: Mr.Yuck] #566676
12/30/09 12:08 PM
12/30/09 12:08 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
This will happen if you get something caught in the latch....... I've also seen the latches go bad.
Re: how to get the trunk open ? tumbler turns but no open [Re: meepmeep70] #566677
12/30/09 12:21 PM
12/30/09 12:21 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I would ask, but I know the answer as well
Re: how to get the trunk open ? tumbler turns but no open [Re: OzHemi] #566678
12/30/09 12:45 PM
12/30/09 12:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Drill out the tumblers and then use a screw driver to turn the latch.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: how to get the trunk open ? tumbler turns but no open [Re: MoparforLife] #566679
12/30/09 12:53 PM
12/30/09 12:53 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The key turns. Unless the rod fell out of the back of the cylinder this won't help, plus it's still better to use a long extension and unbolt the latch.
Re: how to get the trunk open ? tumbler turns but no open [Re: Jim_Lusk] #566680
12/30/09 02:20 PM
12/30/09 02:20 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have taped a screw driver to a broom stick and gone from inside the back seat. You need to stick the screw driver into the elongated slot and give it a turn. The trunk will pop open. A good flash light is a must.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: how to get the trunk open ? tumbler turns but no open [Re: 70gtx440dana] #566681
12/30/09 02:24 PM
12/30/09 02:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah I did something like that once at the track too. I used a long stick. You just need a small enough screw driver to fit in the slot.
Re: how to get the trunk open ? tumbler turns but no open [Re: 70gtx440dana] #566682
12/30/09 04:01 PM
12/30/09 04:01 PM
NY NY
3
NY NY
also a good idea...i still haven't had a chance to head over to the shop but hopefully today or tomorrow.
i will update when complete.
thanks!
mike
Re: how to get the trunk open ? tumbler turns but no open [Re: 70gtx440dana] #566683
12/30/09 04:49 PM
12/30/09 04:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
that was what I was to say... easier than unbolt completelly the latch, even harder to attach a screwdriver with something.
although could it be done with some screwdriver end socket at several rachet extensions, like how you was to remove the latch
Re: how to get the trunk open ? tumbler turns but no open [Re: NachoRT74] #566684
12/30/09 06:57 PM
12/30/09 06:57 PM
NY NY
3
NY NY
i got in....was like finding buried treasure.
Re: how to get the trunk open ? tumbler turns but no open [Re: 340duster340] #566685
12/30/09 07:37 PM
12/30/09 07:37 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: how to get the trunk open ? tumbler turns but no open [Re: OzHemi] #566686
12/30/09 08:07 PM
12/30/09 08:07 PM
Lansing, MI
Lansing, MI
What method did you use to open it? Also, If the pistol grip is for sale PM me.
Re: how to get the trunk open ? tumbler turns but no open [Re: 70gtx440dana] #566687
12/30/09 11:05 PM
12/30/09 11:05 PM
NY NY
3
NY NY
i used the extension and socket method...it was a straight shot to the bolts so i went for it.
Re: how to get the trunk open ? tumbler turns but no open [Re: 340duster340] #566688
12/30/09 11:40 PM
12/30/09 11:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
So was the latch/lock broken or just tight from lack of grease?
Usually you can SMACK the decklid with the key turned & it'll POP!
Re: how to get the trunk open ? tumbler turns but no open [Re: 6bblgt] #566689
12/31/09 10:50 AM
12/31/09 10:50 AM
NY NY
3
NY NY
i think it was a combination of lack of grease AND the torsion rods in the back were removed so the lid is extra heavy. it just didn't want to budge
in retrospect if i had 2 other people there to help me i probably could have turned the key and had 1 guy pull up on either side.
