Re: how to get the trunk open ? tumbler turns but no open
[Re: 340duster340]
#566671
12/30/09 08:53 AM
12/30/09 08:53 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
i have had good luck getting stuck trunk lids open by using the proper socket on A LOT of extensions, 3 or 4 feet worth, and unbolting the latch from the trunk lid from the back seat.
perception is 90% of reality
[Re: 340duster340]
#566673
12/30/09 09:12 AM
12/30/09 09:12 AM
Mr T2U
make sure you have good lighting and a pick up magnet if you drop something.
[Re: meepmeep70]
#566677
12/30/09 12:21 PM
12/30/09 12:21 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
i would also tape extensions together ask me why
I would ask, but I know the answer as well
[Re: MoparforLife]
#566679
12/30/09 12:53 PM
12/30/09 12:53 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Drill out the tumblers and then use a screw driver to turn the latch.
The key turns. Unless the rod fell out of the back of the cylinder this won't help, plus it's still better to use a long extension and unbolt the latch.
[Re: Jim_Lusk]
#566680
12/30/09 02:20 PM
12/30/09 02:20 PM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
I have taped a screw driver to a broom stick and gone from inside the back seat. You need to stick the screw driver into the elongated slot and give it a turn. The trunk will pop open. A good flash light is a must.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#566681
12/30/09 02:24 PM
12/30/09 02:24 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah I did something like that once at the track too. I used a long stick. You just need a small enough screw driver to fit in the slot.
[Re: 70gtx440dana]
#566682
12/30/09 04:01 PM
12/30/09 04:01 PM
Posts: 4,323 NY NY
340duster340
NY NY
also a good idea...i still haven't had a chance to head over to the shop but hopefully today or tomorrow.
i will update when complete.
thanks!
mike
[Re: OzHemi]
#566686
12/30/09 08:07 PM
12/30/09 08:07 PM
70gtx440dana
Lansing, MI
What method did you use to open it? Also, If the pistol grip is for sale PM me.
[Re: 70gtx440dana]
#566687
12/30/09 11:05 PM
12/30/09 11:05 PM
Posts: 4,323 NY NY
340duster340
NY NY
i used the extension and socket method...it was a straight shot to the bolts so i went for it.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
