Re: Floor pan tunnel patch (how to)
[Re: 1962Savoy]
#564961
12/28/09 06:27 PM
12/28/09 06:27 PM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
Unless you are really experienced, I wouldn't advise trying to "butt weld" it. But, if you really feel you have to, you already have a front seam, so the front doesn't need to be butt welded. As far as the rest, cut the patch panel, set it on the hump, and mark it WELL with a magic marker. Then cut the opening too small to start with, like maybe an 1/8 inch or so, and then trim/grind until it fits flush. More work than necessary in my opinion, but do-able.
[Re: Ply72rr]
#564963
12/29/09 01:11 AM
12/29/09 01:11 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Line the new panel up on top of the old pan and secure with screws.Then cut both pans with a thin cut off wheel.The thin wheel should leave the correct gap for butt welding.You should make the first cut and add tack welds,then cut a little more and add more tacks.Keep going like this until you are finished cutting all the way around and it should be lined up perfect.
Best method ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 68jim]
#564969
12/29/09 02:25 PM
12/29/09 02:25 PM
Posts: 416 London,Ontario,Canada
1962Savoy
1962Savoy,
I could not see all of your picture but it sounds likes what I needed to do for my Road Runner. A previous owner converted the column shift to a floor shift for racing. The process posted ealier is pretty much the way to go. I used a fine tooth small pneumatic saw vice a cutting wheel but basically you get the same results. Good luck.
Hey Jim That looks like my floor but not as bad! my opening is twice that size as I think they installed the 4 speed in from the top! LOL ![](/ubbthreads/images/graemlins/laugh2.gif) I'm going to give it a try Thanks Guys!! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 1962Savoy]
#564970
12/29/09 02:44 PM
12/29/09 02:44 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Hows this one... The rust is more surface than anything but some scale.. But I'm not sure if it was a hatchet or a hand grenade that they used for the 4 spd install.. I did a larger repair cause I had the spare floor &doing it this way eliminated all the rust... But the small hole from the driveshaft bouncing around cause there was no trans mount I repaired the way that is being suggested...
Re: Floor pan tunnel...my hole is bigger that yours!
[Re: 1962Savoy]
#564974
12/29/09 04:57 PM
12/29/09 04:57 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
Now would you guys square this hole up to patch it or what???
Same method as discussed earlier. I would definitely use the forward seam as one end. Trim the other sides so it helps your welding skills better. Avoid having to weld in the little valleys if you can...much easier to work the flatter sections and much easier to sand afterwards. After you get the patch area figured out and before you weld it in, go ahead and repair the cross member frame first. The patch will need to have some welds to that frame. I used a MIG, and just drilled some 3/16" holes in the patch metal where the factory had spot welds, and filled it in with the welder. The little circular welds almost look like spot welds but it is not the critical since it will be painted and covered anyway.
[Re: 71DemonRON]
#564976
12/29/09 10:06 PM
12/29/09 10:06 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
The past owner of my rr did this
Wow I can't believe how many people cut a big hole in those dash bezels.... ![](/ubbthreads/images/graemlins/grin.gif)
[Re: QuickBpBp]
#564977
12/29/09 10:12 PM
12/29/09 10:12 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Well as long as we're cutting why stop with a big hole in the floor?? ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: QuickBpBp]
#564978
12/30/09 04:23 PM
12/30/09 04:23 PM
1962Savoy
YOU WIN! YOUR HOLE IS BIGGER THAN MINE ![](/ubbthreads/images/graemlins/haha.gif)
