Floor pan tunnel patch (how to) #564960
12/28/09 04:17 PM
12/28/09 04:17 PM
London,Ontario,Canada
1962Savoy Offline OP
I have to patch in the floor and partial tunnel because someone cut it right out to put a 4 speed in. the floor is not rusty at all solid like the day it was born. I have a patch panel for it from another car and I would like to know what the best way to measure it so it will fit precisly so I can butt weld it in place with no overlap?
Re: Floor pan tunnel patch (how to) [Re: 1962Savoy] #564961
12/28/09 06:27 PM
12/28/09 06:27 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Unless you are really experienced, I wouldn't advise trying to "butt weld" it. But, if you really feel you have to, you already have a front seam, so the front doesn't need to be butt welded. As far as the rest, cut the patch panel, set it on the hump, and mark it WELL with a magic marker. Then cut the opening too small to start with, like maybe an 1/8 inch or so, and then trim/grind until it fits flush. More work than necessary in my opinion, but do-able.
Re: Floor pan tunnel patch (how to) [Re: 1962Savoy] #564962
12/29/09 01:06 AM
12/29/09 01:06 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Line the new panel up on top of the old pan and secure with screws.Then cut both pans with a thin cut off wheel.The thin wheel should leave the correct gap for butt welding.You should make the first cut and add tack welds,then cut a little more and add more tacks.Keep going like this until you are finished cutting all the way around and it should be lined up perfect.
Re: Floor pan tunnel patch (how to) [Re: Ply72rr] #564963
12/29/09 01:11 AM
12/29/09 01:11 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Best method
Re: Floor pan tunnel patch (how to) [Re: Ply72rr] #564964
12/29/09 12:14 PM
12/29/09 12:14 PM
Thanks for the info guys I will have a go at it in the next week or so and let you know how it went.I like the idea of screwing the one down ontop of the othe and cutting both panels together. weather it will work or not it sounds good to me
Re: Floor pan tunnel patch (how to) [Re: 1962Savoy] #564965
12/29/09 12:24 PM
12/29/09 12:24 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
1962Savoy,
I could not see all of your picture but it sounds likes what I needed to do for my Road Runner. A previous owner converted the column shift to a floor shift for racing. The process posted ealier is pretty much the way to go. I used a fine tooth small pneumatic saw vice a cutting wheel but basically you get the same results. Good luck.
Re: Floor pan tunnel patch (how to) [Re: 68jim] #564966
12/29/09 12:26 PM
12/29/09 12:26 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
#2
Re: Floor pan tunnel patch (how to) [Re: 68jim] #564967
12/29/09 12:27 PM
12/29/09 12:27 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
#3
Re: Floor pan tunnel patch (how to) [Re: 68jim] #564968
12/29/09 12:29 PM
12/29/09 12:29 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
# last
Re: Floor pan tunnel patch (how to) [Re: 68jim] #564969
12/29/09 02:25 PM
12/29/09 02:25 PM
1962Savoy,
Hey Jim That looks like my floor but not as bad! my opening is twice that size as I think they installed the 4 speed in from the top! LOL
I'm going to give it a try Thanks Guys!!
Re: Floor pan tunnel patch (how to) [Re: 1962Savoy] #564970
12/29/09 02:44 PM
12/29/09 02:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hows this one... The rust is more surface than anything but some scale.. But I'm not sure if it was a hatchet or a hand grenade that they used for the 4 spd install.. I did a larger repair cause I had the spare floor &doing it this way eliminated all the rust... But the small hole from the driveshaft bouncing around cause there was no trans mount I repaired the way that is being suggested...
Re: Floor pan tunnel patch (how to) [Re: 1_WILD_RT] #564971
12/29/09 02:45 PM
12/29/09 02:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Almost fixed, the small patch is only tacked
Re: Floor pan tunnel patch (how to) [Re: 1_WILD_RT] #564972
12/29/09 04:12 PM
12/29/09 04:12 PM
now thats starting to look like it!that hole looks like a IED did that one!
Re: Floor pan tunnel...my hole is bigger that yours! [Re: 1962Savoy] #564973
12/29/09 04:16 PM
12/29/09 04:16 PM
Now would you guys square this hole up to patch it or what???
Re: Floor pan tunnel...my hole is bigger that yours! [Re: 1962Savoy] #564974
12/29/09 04:57 PM
12/29/09 04:57 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Same method as discussed earlier. I would definitely use the forward seam as one end. Trim the other sides so it helps your welding skills better. Avoid having to weld in the little valleys if you can...much easier to work the flatter sections and much easier to sand afterwards. After you get the patch area figured out and before you weld it in, go ahead and repair the cross member frame first. The patch will need to have some welds to that frame. I used a MIG, and just drilled some 3/16" holes in the patch metal where the factory had spot welds, and filled it in with the welder. The little circular welds almost look like spot welds but it is not the critical since it will be painted and covered anyway.
Re: Floor pan tunnel patch (how to) [Re: 1962Savoy] #564975
12/29/09 09:59 PM
12/29/09 09:59 PM
PORT ALBERNI B.C. CANADA
71DemonRON Offline
71DemonRON  Offline
The past owner of my rr did this
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter
1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
Re: Floor pan tunnel patch (how to) [Re: 71DemonRON] #564976
12/29/09 10:06 PM
12/29/09 10:06 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Wow I can't believe how many people cut a big hole in those dash bezels....
Re: Floor pan tunnel patch (how to) [Re: QuickBpBp] #564977
12/29/09 10:12 PM
12/29/09 10:12 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well as long as we're cutting why stop with a big hole in the floor??
Re: Floor pan tunnel patch (how to) [Re: QuickBpBp] #564978
12/30/09 04:23 PM
12/30/09 04:23 PM
YOU WIN!
YOUR HOLE IS BIGGER THAN MINE
Re: Floor pan tunnel patch (how to) [Re: 1962Savoy] #564979
12/30/09 04:30 PM
12/30/09 04:30 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Holy crap, they really did take a huge chunk out! But yeah, what these guys said, and if you end up with spots less than perfect after welding, you can use smooth fiberglass..........it's like bondo, only it is fiberglass without the hairs in it. Great stuff, NAPA has it.
