Milodon gear drive fitment issues with Hemi Block #564369
12/27/09 10:40 PM
12/27/09 10:40 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
I have attached some pics to show the interference issues. It fits my 440 block no problem. I am not sure what these bosses are for, and before grinding I thought I should ask.
Re: Milodon gear drive fitment issues with Hemi Block [Re: Forest] #564370
12/27/09 10:41 PM
12/27/09 10:41 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Here is what hits on the cover side.
Re: Milodon gear drive fitment issues with Hemi Block [Re: Forest] #564371
12/27/09 10:48 PM
12/27/09 10:48 PM
Springboro, Ohio
Hollywood Offline
Hollywood  Offline
Springboro, Ohio
Yes, you need to grind it down. I had to do the same thing on my 528 block.
Re: Milodon gear drive fitment issues with Hemi Block [Re: Hollywood] #564372
12/27/09 11:01 PM
12/27/09 11:01 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
How about dowel pins any advice on getting them stubborn boogers out?
Re: Milodon gear drive fitment issues with Hemi Block [Re: Forest] #564373
12/27/09 11:16 PM
12/27/09 11:16 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
not that you can't get the pins out with other methods but if you know anyone at an automotive machine shop a dowel pin puller is really the best way. it's one of my tools that gathers a lot of dust but man are they handy when you need one.
Re: Milodon gear drive fitment issues with Hemi Block [Re: Forest] #564374
12/28/09 06:12 PM
12/28/09 06:12 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
You will also have to clearance the 3/8 pipe plug boss that connects the outlet of the oil pump to the passengers side oil galley. Once you remove the obvious interference areas you have marked, it will then hit the boss. Grind-mock-check-repeat
Re: Milodon gear drive fitment issues with Hemi Block [Re: MuscleMike] #564375
12/28/09 07:15 PM
12/28/09 07:15 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Typical clearence issues.As far as the dowels go,get a thick nut that will fit over it,zap it with a mig welder(dowel to nut)turn it while it still hot with a box wrench or socket while prying outward with a small crowsfoot or screw driver.Just leave enough room between the nut and block to pry against.The cast block will expand more than the steel dowel pin.
Re: Milodon gear drive fitment issues with Hemi Block [Re: B G Racing] #564376
12/28/09 07:36 PM
12/28/09 07:36 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Bob, that will work for sure, but dont forget that those dowel pins are oversize, they are not 1/4", so he may not be able to re-use them with that method, or just make sure you get a spare set before you start.
RIP Monte Smith
Re: Milodon gear drive fitment issues with Hemi Block [Re: CompWedgeEngines] #564377
12/28/09 08:44 PM
12/28/09 08:44 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Thanks everyone for your help! The kit comes with new dowels. Thanks again.
Re: Milodon gear drive fitment issues with Hemi Block [Re: Forest] #564378
12/28/09 09:02 PM
12/28/09 09:02 PM
Syracuse,NY
Syracuse,NY
Gotcha...I thought you were maybe removing a set that was already installed....my bad. As an FYI, the dowels are slightly oversize by a few thousanths to make a better press fit when using the standard type drill bit.
Good luck.
RIP Monte Smith
