Re: Milodon gear drive fitment issues with Hemi Block
[Re: B G Racing]
#564376
12/28/09 07:36 PM
12/28/09 07:36 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Bob, that will work for sure, but dont forget that those dowel pins are oversize, they are not 1/4", so he may not be able to re-use them with that method, or just make sure you get a spare set before you start.
RIP Monte Smith
[Re: Forest]
#564378
12/28/09 09:02 PM
12/28/09 09:02 PM
CompWedgeEngines
Syracuse,NY
Gotcha...I thought you were maybe removing a set that was already installed....my bad. As an FYI, the dowels are slightly oversize by a few thousanths to make a better press fit when using the standard type drill bit.
Good luck.
RIP Monte Smith
