Re: Restoring Red Interior - Help!
[Re: packin3deuces]
#564328
12/27/09 09:16 PM
12/27/09 09:16 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: Redbird]
#564331
12/28/09 01:27 AM
12/28/09 01:27 AM
Posts: 565 IA
landon1
IA
i don't know about the e-bodies, but on the 3rd gen Bs, the 71s got color-coordinated seat belts and housings, clips, etc. while in 72 i believe, they standardized all belt/housing colors to black. there wasn't a red interior on that style, so not sure if they made red belts or not (fairly rare i would think) - even if they were black, i would only assume that the housings would be red
'71 Satellite Sebring 440
[Re: packin3deuces]
#564332
12/29/09 12:28 AM
12/29/09 12:28 AM
Posts: 2,309 South, FL
cudaized
South, FL
I am restoring the factory red interior in my '70 'Cuda that the previous owner dyed black. I am not sure what color - red or black - a few of the parts should be. The car has a rim blow steering wheel and red seat belts. Should the rim blow center pad be red or black? Also, which color do the shoulder belt clips get dyed? And the front lap belts have a plastic boot at their base where they mount to the floor - which color, red or black? Thanks in advance for any help you can provide.
Hi, Having owned several Red interior 1970 `cudas, please allow me to assist. Rim Blow center = Red Shoulder belt clips = Red Front lap belt bezel = Red Most items were Red.
If you have the C15 option - Deluxe Seat Belts, then the actual seat belt webbing will be Red also. Other wise, black webbing. It sounds like you have the C15 option. Make sure that you have the actual Deluxe Seat belts. The buckles are different from a standard seat belt. Ola Nilsson cudaized@cudaized.com
