Mopar Perf Distributor Help #562325
12/25/09 04:03 PM
12/25/09 04:03 PM
Cumberland City, TN
dhutch Offline OP
dhutch  Offline OP
Cumberland City, TN
I've searched through the forums and tech archives for this. I'm trying to find any info on how to limit a mopr perf dist that's in my 440. I have an ideal on how to do it, I just don't want to mess it up and would rather have some advice from those that know before I start. Any help is appreciated.
'70 R/T Challenger '06 Chevy D-max Crew
Re: Mopar Perf Distributor Help [Re: dhutch] #562326
12/25/09 04:13 PM
12/25/09 04:13 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
There are torx headed screws that lock the slots in place.
The slots can be adjusted quite a bit. typically they are wide oopen fromt he factory which gives you too much mechanical advance.
I belive there is some spec info in the achives about slot length vs advance amounts.
You then adjust when it comes in by selecting different springs for the weights.
Re: Mopar Perf Distributor Help [Re: dhutch] #562327
12/26/09 08:09 AM
12/26/09 08:09 AM
the house on the left.
cogen80 Offline
cogen80  Offline
tells ya in here. http://static.summitracing.com/global/images/instructions/dcc-3690426.pdf
Re: Mopar Perf Distributor Help [Re: dhutch] #562328
01/01/10 10:03 AM
01/01/10 10:03 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
AS stated the slot length can be varied by lossening the torx lock screws. To make it much easier Summit Jegs sells a Mallory (the MP distributor is made by Mallory) kit with spacers that make setting the amount of timing a snap. The kit also comes with a 1/2 dozen differnt sets of sprngs for adjusting the rate. The instuctions include graphs for the different spring combos so you will know what you ae getting. The kit number is 29014.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Mopar Perf Distributor Help [Re: dgc333] #562329
01/01/10 08:00 PM
01/01/10 08:00 PM
Cumberland City, TN
dhutch Offline OP
dhutch  Offline OP
Cumberland City, TN
Thanks for the info. I picked up the curve kit from summit racing.
Re: Mopar Perf Distributor Help [Re: dave571] #562330
01/01/10 08:56 PM
01/01/10 08:56 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
somebody posted somewhere in here about they were set at 28º degrees. I think it was somebody worked at Mallory. It was floated recently on a newer phasing dist thread posting an old thread about the timming
