Alcohol motors #559398
12/21/09 05:02 PM
12/21/09 05:02 PM
lLas Vegas, Nv
P
Prayer Warrior Offline OP
P
lLas Vegas, Nv
Guys, Got a 452" big block that runs on methanol. My problem is getting the car to start after not running for an extended period time, say overnight. It just does`nt seem to fire off as a gas motor. It takes a lot of starts to finally get it to fire up and when does it run and starts as it should. Is this normal for alcohol motors? Anybody got any ideas?
Re: Alcohol motors [Re: Prayer Warrior] #559399
12/21/09 05:16 PM
12/21/09 05:16 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
do you squirt a couple oz. of gas in for initial startup?? That's all I do with my motors and once they've run a pump or 2 of the throttle and they start right up.
Re: Alcohol motors [Re: MegaDart] #559400
12/21/09 05:29 PM
12/21/09 05:29 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Just pour/squirt a little gasoline in the carb on the first start up of the day to make your life a lot easier.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Alcohol motors [Re: Prayer Warrior] #559401
12/21/09 06:39 PM
12/21/09 06:39 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What type of induction? If its a carb..you really shouldn't need to prime..But most mech injection setups like the Flying toilet doesn't have a accelerator pump.So pump the pedal does nothing, and with those mech belt driven fuel pumps, the engine doesn't spin fast enough to prime them up well.
Re: Alcohol motors [Re: Bob_Coomer] #559402
12/21/09 08:10 PM
12/21/09 08:10 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I run an alky carb and a belt drive pump. Priming with gas REALLY helps starting... eliminated kickback, burned up starters, etc. I do it every time. It also keeps engine running long enough to spin the pump up and fill the bowls.
Alky motors can be cold blooded till they get some heat in them.
Re: Alcohol motors [Re: MegaDart] #559403
12/22/09 07:28 AM
12/22/09 07:28 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I have the same set up on the tractor and it always starts better with a shot of gas. Our last pull this year it was only about 5 degrees Celsius and without a shot of gas at that temperature it will start eventually but like Wayne says it is hard on the starter. I usually only give it a shot on the first warm up of the day.
Re: Alcohol motors [Re: mac56] #559404
12/22/09 09:06 AM
12/22/09 09:06 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
that is what I meant to say
Re: Alcohol motors [Re: MegaDart] #559405
12/22/09 09:30 AM
12/22/09 09:30 AM
Mid-Ohio
Bakaruda432 Offline
mopar addict
Bakaruda432  Offline
mopar addict
Mid-Ohio
Why does Ethanol or Methanol have a hard time lighting and E-85 doesn't?
Re: Alcohol motors [Re: Bakaruda432] #559406
12/22/09 09:54 AM
12/22/09 09:54 AM
gregsdart Online content
gregsdart  Online Content
The fifteen percent gas in E85 helps light off the alky.
Re: Alcohol motors [Re: Bakaruda432] #559407
12/22/09 10:50 AM
12/22/09 10:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Even with 15% gas in the E-85 I still have some problems
to get it fired up if its below about 40-45 degrees
without pumping the carb 4-5 times, even then it still
farts back through the carb some..... thats why there
is winter grade E-85(they change the blend to about
E-70... 30% gas for winter)
Re: Alcohol motors [Re: Prayer Warrior] #559408
12/22/09 01:20 PM
12/22/09 01:20 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
Just a few questions...I have delt with methanol for a long time now..
What kind of induction setup are we talking and what kind of pump?
Is it hard to start when its warm outside or just cold?
I can take either one of my cars above 45 degrees and start just like a gas motor on the first start of the day no matter how long its been setting and thats without using gas.
Re: Alcohol motors [Re: sc301v] #559409
12/23/09 04:29 PM
12/23/09 04:29 PM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
If you got a good spark methanol should not be too hard to start mine would get a bit hard to start below 30 to 35 degrees but would still start into the mid to upper 20s with no gas
I like my 7AL it will fire about any mixture
