Re: CSI water pump not circulating
[Re: rebel]
#558197
12/20/09 10:49 AM
12/20/09 10:49 AM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
When I first switched to a Meziere I could NOT get the thing to circulate water. I bought one of these kits off Ebay for around $75 to fill the system with no air pockets and haven't had any trouble since. The air bleed setup looks alot easier but this method works well.
[Re: moparbud]
#558200
12/20/09 11:10 PM
12/20/09 11:10 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
You have an air pocket somewhere. I had to loosen the bolts on mine to make a vent to get it to pump. Do this with the pump on and also try squeezing the hoses to get something to move.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: moparbud]
#558201
12/20/09 11:20 PM
12/20/09 11:20 PM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
i put my csi water pump on. and it is not moving any water in the radiator. i checked the fins and all looks good. can some one tell me what i am doing wrong.
This is a common problem. We changed two pumps last year and both pumps did this on two different cars. In most cases its just a priming issue. Like mentioned above air pockets seem to be the cause. If memory serves me right cant you change the water flow just by switching the wires around? Also first things first. We need to check & see if the pump is actually working. You said you checked the fins? 1) Does this mean you checked voltage coming in to the pump? 2) Did you check the pump while off the motor and watch the fins propel when the switch is activated?
[Re: bigtimeauto]
#558203
12/21/09 12:26 AM
12/21/09 12:26 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Stupid question but is the radiator above the water neck on the pump? Take the top radiator hose off the tank, leave the cap off the radiator fill it up, cycle the pump a few times, it best to have a extra set of hands.... Those little bleeds work...they are stock on a bunch of Chrysler cars....3.5 and 3.3 V-6's have them...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 67dodgeracer]
#558205
12/31/09 05:01 PM
12/31/09 05:01 PM
Posts: 88 Regina Sask, Canada
Viper469
Regina Sask, Canada
Does anyone have part #'s for the bleeder screws?My mopar alum. housing has an 1/8" pipe port on top that would work great.I went to a couple parts houses,and no one could help. Does it really work even though the bleeder is lower than the top of the radiator?I have a stock radiator in my coronet,and see no water movement,but it does cool o.k.I should see water moving,right?
I just used brake bleeder screw. Should be easy to find at any parts store. The port will have to be at the highest point in the water pump housing. Yes the bleeder screw works very well. If you have no water movement your car would most likely overheat in a matter of minutes.
[Re: 67dodgeracer]
#558206
12/31/09 05:21 PM
12/31/09 05:21 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Your trying to bleed tha air out of the pump not the whole system. It will get the pump flowing for sure. I just tapped mine 10/32 and put a screw with a gasket on it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: moparbud]
#558207
12/31/09 05:21 PM
12/31/09 05:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Have you warmed the engine up yet.... every year when I drain the anti freeze and fill it with water and water wetter I have the same issue... I warm up the engine some(feel by hand cause the gauge wont be right) then I squash the hose a few times and it will finally prime..... also try jacking the front of the car up so the air in the block will try to head to the radiator
