68 cuda factory 4-speed shifter #556981
12/18/09 04:34 PM
12/18/09 04:34 PM
Carrollton, Georgia
U
uwg Offline OP
uwg  Offline OP
U
Carrollton, Georgia
It has been a long time since I posted on this forum but I could use some help for the experts.
I have a 1968 Barracuda Formula S 383 4-speed. The car was NOT equipped with a center console. I am in the middle of putting it back together when I ran across 2 different shifters. I need to know which one is supposed to go in this car. They both have the same general shape except one is slightly longer than the other.
My suspicions are the longer shifter is for a car with a center console and the shorter one is for non-center console. Also, the shorter shifter has a number stamped at the base where the three bolts are of "44532" while the longer on does not.
Any help would be greatly appreciated!!!
Re: 68 cuda factory 4-speed shifter [Re: uwg] #556982
12/18/09 04:41 PM
12/18/09 04:41 PM
Carrollton, Georgia
U
uwg Offline OP
uwg  Offline OP
U
Carrollton, Georgia
Re: 68 cuda factory 4-speed shifter [Re: uwg] #556983
12/18/09 05:04 PM
12/18/09 05:04 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
They both look like console ones. One is probably for a B-body. I don't think the non-console one needs that much of a bend it it.
If I can easily lay my hands on the one from my '68, I can take some measurements. Mine is a console 383 4-speed car.
Re: 68 cuda factory 4-speed shifter [Re: NicksGarage] #556984
12/18/09 05:34 PM
12/18/09 05:34 PM
michigan woods
imfixinmopars426 Offline
michigan woods
they look like 66-67 style,maybe console something,three bolt style wasnt in my 68 cuda. look on brewers site,maybe they have pics?
Re: 68 cuda factory 4-speed shifter [Re: imfixinmopars426] #556985
12/18/09 08:08 PM
12/18/09 08:08 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Early '68s use this syle of shifters then they switched back to the Hurst ones.
Re: 68 cuda factory 4-speed shifter [Re: NicksGarage] #556986
12/18/09 10:44 PM
12/18/09 10:44 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Here's the shifter from my car. The angle of the bend looks different than yours. So maybe yours is for a non-console.
Re: 68 cuda factory 4-speed shifter [Re: uwg] #556987
12/18/09 11:02 PM
12/18/09 11:02 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I've also got a non console, 383 4spd 68 Formula S & will try to get some pics this weekend & post them.
Re: 68 cuda factory 4-speed shifter [Re: NicksGarage] #556988
12/19/09 02:15 AM
12/19/09 02:15 AM
Carrollton, Georgia
U
uwg Offline OP
uwg  Offline OP
U
Carrollton, Georgia
Thanks for the picture and youre right. The bend in yours looks like it is less than 90 degrees. I will measure mine tomorrow for length.
But now the question is if the bend in yours is correct for a console and both of mine are a different, then why is one longer than the other. Bench seat vs bucket seats?
Re: 68 cuda factory 4-speed shifter [Re: Triggerfish] #556989
12/19/09 02:27 AM
12/19/09 02:27 AM
Carrollton, Georgia
U
uwg Offline OP
uwg  Offline OP
U
Carrollton, Georgia
That would be great if you could post those. Thanks!
Re: 68 cuda factory 4-speed shifter [Re: uwg] #556990
12/19/09 03:17 AM
12/19/09 03:17 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I still think the difference would be that one is an a-body and one is a b-body. Or maybe they're not mopar at all.
Re: 68 cuda factory 4-speed shifter [Re: NicksGarage] #556991
12/20/09 03:11 PM
12/20/09 03:11 PM
Carrollton, Georgia
U
uwg Offline OP
uwg  Offline OP
U
Carrollton, Georgia
My measurements turn 9 1/2" for the short one and about 12 1/2" for the long one.
Re: 68 cuda factory 4-speed shifter [Re: uwg] #556992
12/20/09 03:50 PM
12/20/09 03:50 PM
Russ H. Offline
Russ H.  Offline
The Picture posted by Nicks Garage is identical to my 68 Barracuda console equipped Inland Shifter.
Russ
Re: 68 cuda factory 4-speed shifter [Re: Russ H.] #556993
12/20/09 04:17 PM
12/20/09 04:17 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Don't forget that C-body cars used the Inland Shifters through early 68 as well. They look VERY similar to the B-body handles but were slightly longer.
Re: 68 cuda factory 4-speed shifter [Re: ScottSmith_Harms] #556994
12/20/09 08:58 PM
12/20/09 08:58 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: 68 cuda factory 4-speed shifter [Re: autoxcuda] #556995
12/21/09 12:20 AM
12/21/09 12:20 AM
Carrollton, Georgia
U
uwg Offline OP
uwg  Offline OP
U
Carrollton, Georgia
Thanks for the pics. That looks like the shorter one. Think you could measure it for me just to make sure?
Re: 68 cuda factory 4-speed shifter [Re: uwg] #556996
12/21/09 12:33 AM
12/21/09 12:33 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Longer Inland shifter is B Body and the shorter is for an A with a console
Re: 68 cuda factory 4-speed shifter [Re: uwg] #556997
12/21/09 01:21 AM
12/21/09 01:21 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Not my car. The link is to the owner of the car: http://www.forabodiesonly.com/mopar/showthread.php?t=83709
Re: 68 cuda factory 4-speed shifter [Re: dart4forte] #556998
12/21/09 01:42 AM
12/21/09 01:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You mean without console?? Refering to the picture uwg posted in the 2nd post of this thread??
That shorter shifted does not look like the with console one Nicksgarage posted
Re: 68 cuda factory 4-speed shifter [Re: autoxcuda] #556999
12/21/09 01:58 PM
12/21/09 01:58 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
When mounted in the car, the console one angles about 45 degrees to the right and toward the dash to get it to come up through the console. I don't have the transmission in my car so I can't mount it to show that.
Re: 68 cuda factory 4-speed shifter [Re: NicksGarage] #557000
12/21/09 02:08 PM
12/21/09 02:08 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
In the original picture, I believe the top unit is b-body with console & the lower is c-body with console.
