Plug Wires vs Headers
#554879
12/15/09 11:16 PM
12/15/09 11:16 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
I'm slowly working on gathering the parts needed to swap a 440 into my 86 truck. I've already got all the parts that everyone says you need for the swap: motor mount brackets, rear sump pan with dipstick and pickup, and headers. I also need a small booster, but I will get that new and I do have the bb trans also. My question concerns the use of headers and what type of plug wires do I need: straight boot or 90 degree? The motor has the 452 heads if it makes a difference. The wires are on my list of items I still need to get, along with the rest of the tune-up (plugs and cap/rotor), a carb, air cleaner, and a kickdown cable. Other than that, I just need the basic essentials like belts and fluids. I was looking at some plug wire sets online and the one thing that kept coming up was straight or 90* boots so I need to figure out which I need to use with the headers. I'm thinking the straight ones might be best. What do you suggest? Also, can anyone recommend a good set of wires for around $50? I'd love to buy the Firecores, but they are way beyond my price range. Thanks!
Re: Plug Wires vs Headers
[Re: dodgeram440]
#554881
12/15/09 11:30 PM
12/15/09 11:30 PM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
I think there was a thread or two about this recently and if i remember most guys said they were better off making there own set using the straight 45s or 90s which ever one worked the best.
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
[Re: 70Cuda383]
#554885
12/15/09 11:44 PM
12/15/09 11:44 PM
dodgeram440
Piqua, Ohio
around $50? aren't the firecores only $80?
According to his website up there, it looks like they start at $105. Even $80 really would be beyond my budget. I was looking at a set of Taylors on Jegs that were $60. I think I could squeeze that for a good set of wires. I ran a set of Taylors on a 440 once, but that was like 15 years ago and I don't rememer the details about the set I used. And those headers were different than the ones I have for the truck.
[Re: dodgeram440]
#554887
12/16/09 12:14 AM
12/16/09 12:14 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
We run the Taylors on all our SB and BBs with headers.My 440 2 inch tubes my kids 413 2 1/8 tubes.We just run the stock wires that they make.Mine are at least 10 years old and still great.My kids are 3 years old no problems with his BB wires either.I hear the FireCores are a good wire though.Rocky
Chrysler Firepower
[Re: dodgeram440]
#554889
12/16/09 03:58 PM
12/16/09 03:58 PM
dodgeram440
Piqua, Ohio
Ok, took some pics today. I didn't have any actual header bolts so I just used a couple bolts to hold the headers in place. This is the first time I've even had the headers this close to the engine. From what I can tell, it looks like cylinders 2 and 8 need to be 90* boots, all the others can be straight or 90 I guess. So what do y'all think? Please don't make fun of my crappy rusty headers or chipped up valve covers. It's the best I can do on a beggars budget. Right side close up Cylinder #2 Full right side Left side close up Left side front Full left side
[Re: GTXKen]
#554891
12/16/09 04:43 PM
12/16/09 04:43 PM
DaytonaTurbo
Manitoba, Canada
Look into getting bulk wire and crimping your own ends. Then you can buy different boots for different plugs. I think I am running some straight, some 90 and some 45.
I bought the firecores and if I had to do it again, this is what I would do. The set I bought had the 45* bends, and for some header tubes, that just didn't get enough clearance so I ended up burning up and replacing two of them shortly after installation. No problems since.
[Re: DaytonaTurbo]
#554892
12/16/09 05:36 PM
12/16/09 05:36 PM
dodgeram440
Piqua, Ohio
After seeing the headers mounted up in place, I'm thinking 90* boots will work ok for what I need. I don't know of too many sets that come with a combination of different angles, it's either one or the other. The two end plugs on the right side definatly need 90s. The two end ones on the left side could go either way, and the four center plugs have enough room for straights, but could use the 90s also.
So now I can narrow my search down to wire sets with 90* boots. I also want wires that are made to fit a big block Mopar, not one with wires that will wrap around the fender. That's what I like about the Firecores, but, wow, that's some money.
[Re: dodgeram440]
#554893
12/16/09 08:42 PM
12/16/09 08:42 PM
therocks
Niles , Ohio
The Taylor Spiro Pros we use are made for the 440.You have a ton more clearance than we have on both our cars.Rocky
Chrysler Firepower
[Re: sunroofgtx]
#554895
12/16/09 10:01 PM
12/16/09 10:01 PM
dodgeram440
Piqua, Ohio
DANG!!! That's purdy! So what you're saying is that even with the headers I would run the wires underneath like they are in your pics (except for the back two)? I was thinking of coming around the front of the valve cover and over the top of the headers (except for the front two). I'm not really looking for a factory stock look, but something that looks good and clean. I know that seems redundant with the rusty old headers, but I plan to clean those up and paint them. (If my career change pans out for me, I'll have the money to get them ceramic coated at a local company, but that is aways off yet.) So can everybody post pics of how they have heir wires run with headers? I know car headers are different than the truck headers, but that would give me some ideas. Thanks!
[Re: dodgeram440]
#554896
12/17/09 12:03 AM
12/17/09 12:03 AM
therocks
Niles , Ohio
We run ours thru the RMS looms that bolt on the valve cover and then I run them under the headers.Those tiny headers dont need small plugs.My 2 inch TTIs and my kids 2 1/8 both use standard plugs though I have the 5/8 plugs with the aluminum heads now.He still runs the 13/16 standard plugs.Rocky
Chrysler Firepower
[Re: therocks]
#554897
12/19/09 06:16 PM
12/19/09 06:16 PM
Posts: 565 IA
landon1
IA
i have the "make your own" $30 accel wires on my 440 using some of the separator/holders in the kit plus some morosos i had from before not the prettiest, but they work and it was cheap...someday i wouldn't mind getting some better blue wires with made for you vertical looms, just wasn't in the cards when spending the rest of the money on the motor
'71 Satellite Sebring 440
[Re: landon1]
#554898
12/19/09 11:52 PM
12/19/09 11:52 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Actually, it really looks like , with your headers, and if you get short spark plugs, you can run them just like my pics. Exactly.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
