hemi exhaust #554532
12/15/09 06:33 PM
12/15/09 06:33 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Who makes the most accurate exhaust (from manifold flange to tip) for a 68 runner? I like the ease of TTI, but the TTI markings don't cut it for me in going for a points car. Also, what muffler is best? I like the sound of Flowmasters but I know that they are not correct. Suggestions are welcomed and needed.
Re: hemi exhaust [Re: TrueTripleX] #554533
12/15/09 07:29 PM
12/15/09 07:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Gardner 1st followed by Accurate 2nd
Who ever makes Yearone's, DEAD last.
Re: hemi exhaust [Re: gtx6970] #554534
12/15/09 07:34 PM
12/15/09 07:34 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Bill,
What do you think of Dale's Cuda Shop complete exhaust?
Ray
Re: hemi exhaust [Re: gtx6970] #554535
12/15/09 08:25 PM
12/15/09 08:25 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Re: hemi exhaust [Re: XXHEMI] #554536
12/15/09 09:19 PM
12/15/09 09:19 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: hemi exhaust [Re: Snoopy] #554537
12/15/09 10:12 PM
12/15/09 10:12 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
And then there's Don's in Ohio...makes some of the nicest exhaust systems I've seen and used...67 Hemi H-pipe..
Re: hemi exhaust [Re: mccannix] #554538
12/15/09 10:14 PM
12/15/09 10:14 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Tailpipes with all proper contours
Re: hemi exhaust [Re: mccannix] #554539
12/15/09 10:23 PM
12/15/09 10:23 PM
Snoopy Offline
Snoopy  Offline
Terry,
Does Don's have a website? If not, can you supply contact information?
Re: hemi exhaust [Re: Snoopy] #554540
12/15/09 10:28 PM
12/15/09 10:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've not had any dealings with Dales pipes so I can't comment with confidence.
I'm helping a friend that will be installing a complete exhaust from Don's on a 67 R/T Vert after the holidays and will report back with results
Re: hemi exhaust [Re: mccannix] #554541
12/15/09 10:29 PM
12/15/09 10:29 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
used with Dale's pentastar, date code mufflers, all for a perfect fit, no tweaking anywhere.
Re: hemi exhaust [Re: mccannix] #554542
12/15/09 10:36 PM
12/15/09 10:36 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
No website but his contact info is:
Don's Custom Exhaust
2170 Parks Ave SE
Paris, OH 44669
330-862-2096
Re: hemi exhaust [Re: mccannix] #554543
12/15/09 11:33 PM
12/15/09 11:33 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I have Dale's mufflers on my A12 and they sound very good. They seem to be very free flowing
Re: hemi exhaust [Re: RoadRunnerJD] #554544
12/16/09 12:46 AM
12/16/09 12:46 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
is Don's the guy with the class C camper in the swap meet end of the aisle every year?
I think so, anyway, I got one for my 68 Roadrunner and it was not a great fit...
I am using repo exaust manifolds, but the distance between the manifolds was about an inch off and the back end of the pipes where the mufflers mount was off a few inches to one side.
Had to pull out the hot wrench and massage it to get it to fit.. one side was hitting the driveshaft and the other was pointing outward.
Re: hemi exhaust [Re: sthemi] #554545
12/16/09 02:00 PM
12/16/09 02:00 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I have used both Dale's and Dons pipes and I have had problems with both. I am always having to redo one of the headpipe flanges because if that is off at all you will have a muffler rubbing your driveshaft. If you heat any of the pipe too much you will burn off the aluminizing coat. It's also pretty much impossible to fit an entire prebent pipe back into a bender to tweak it some more. Lord knows I've tried! If you are buying an H-pipe you better pray that thing is deadnuts on or you're in for a cussing fit. Next time I'll request the crossover pipe come separate so that I can fit it in last.
Re: hemi exhaust [Re: gtx6970] #554546
12/16/09 02:22 PM
12/16/09 02:22 PM
Ball Ground GA
Ball Ground GA
Thanks Bill. I always trust your advice. I just spoke to Gardners and Eric is great. We do have one MINOR question. On the 68 Hemi California cars, did they come with turndowns or chrome tips and with or without resonators?
Re: hemi exhaust [Re: TrueTripleX] #554547
12/16/09 02:31 PM
12/16/09 02:31 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
'68 parts Catalog shows NO distinction for "California Exhaust".
HEMI - Belvedere & Coronet:
H-pipe / Mufflers / over axle with Resonators / chrome Extentions
Re: hemi exhaust [Re: 6bblgt] #554548
12/16/09 03:55 PM
12/16/09 03:55 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
My Accurate system for my 67 R/T with a crossover was dead nuts on... I bolted it up and havent looked at it since......
Re: hemi exhaust [Re: minivan] #554549
12/17/09 10:37 AM
12/17/09 10:37 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I also went with an Accurate system for my 68 Hemi Road Runner. The fit to the manifolds was perfect and the only mod I did was to weld my resonators to the pipes that fit over the axle. You can get them either way and I initially ordered as separate pieces. In my case, as I was putting the system together, it made more sense for me to make those parts as one item for easier installation. However, to install it as one piece you need to have the car on a lift (my case) or put that part of the exhaust in place before the rear end goes in. I also needed to trim down the nipple for the heat tube about 3/4" - 1" or so for a better fit. I upgraded my Hemi mufflers to the "aggressive" sound models and I'm very happy with the tone. I have 4:10 gears in the car and at highway speeds I can still enjoy the radio or have a conversation. When I hit the loud pedal I hear mostly carburators vice exhaust - sounds awesome! Here are links to a couple of short videos to give you a sample of the sounds.
http://www.youtube.com/watch?v=YMutENguP8E
http://www.youtube.com/watch?v=l-bhI1FDUWE&feature=related
68 Hemi Road Runner
Re: hemi exhaust [Re: 68jim] #554550
12/17/09 01:48 PM
12/17/09 01:48 PM
California
mickm Offline
mickm  Offline
California
68 Hemi Road Runner
ever notice how in 90% of the videos of burnouts, the person taking the video, (or someone else watching), is either giggling or laughing
nice car, btw!
Re: hemi exhaust [Re: 68jim] #554551
12/17/09 02:48 PM
12/17/09 02:48 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
Looks and sounds good Jim, I also like the Accurate HP mufflers. All the other repos seem to be over baffeled and too quiet compaired to original mufflers I have used. I have used 5 or 6 Accurate hemi systems over the years and only had minor trouble with one of them, it rattled on the torsion bar crossmember, easy to fix.
Mike
