Page 7 of 11 1 2 5 6 7 8 9 10 11
Re: Dave Morgan chassis seminar a success [Re: TS3303] #553100
12/18/09 02:46 AM
12/18/09 02:46 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
THIS POST IS FOR DRAG RACING, TRACK ONLY CARS......One more time for those who came late to the party. A perfectly straight driveline, eats the least power and is the reason that tube chassis cars are set up and built as they are, to be as close to that as possible. As drag racers, that is what we want, the absolute least loss of power. Your transmission output is where it is in most cars and you can't move it. For a given ride height, your front joint has an angle that can be changed very little, so you deal with it. Your rear angle however can be dealt with, by raising or lowering the pinion. If our goal is the least power loss, that means we want the driveline to be as straight as possible "UNDER POWER". So we guess, at about where we think the pinion will be, "UNDER POWER", taking into account suspension deflection, and set the shaft to pinion angle, to achieve as straight a driveline angle as we can, while "UNDER POWER". Now this is strictly a guess, as suspension is dynamic during the entire run, meaning it is NOT STATIC and is constantly changing. Equal joint angles, parallel center line planes and all that other crap, go straight out the window when you drop the hammer, because as the suspension moves, it is never in that spot again. Now if you go to the trouble to do all that stuff, she may be super smooth while you are towing or idling back up the return road and well yeah, I guess that may be the most important thing to some, but just not me. If it rides around the pits and don't throw the shaft out, it is good enough. Where it is going down the track is what counts and me personally, I want that to be as close to a straight line as I can get it.
Monte
Notice, this post was made without the expressed written consent of Quicktree or Dave Morgan and does not express their views. These opinions, are only those expressed by the poster, and as such, said opinions are not to be taken as gospel and are only intended for informational purposes
Re: Dave Morgan chassis seminar a success [Re: TS3303] #553101
12/18/09 03:32 AM
12/18/09 03:32 AM
Q
Quicktree Offline OP
Q
I actually asked Monte if he had ever mapped the pinion angle during a full run. His reply was basically why if your not having problems.
maybe Tony can have Dave have racepak hook him up with the proper sensors to install on different suspension/power cars to see what it really does.
I think he plans on doing that at some point.
Re: Dave Morgan chassis seminar a success [Re: Monte_Smith] #553102
12/18/09 07:47 AM
12/18/09 07:47 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
Re: Dave Morgan chassis seminar a success [Re: Quicktree] #553103
12/18/09 08:45 AM
12/18/09 08:45 AM
Lebanon,IN
mr2performance Offline
Lebanon,IN
"I think he plans on doing that at some point."
That would be a huge waste of time, kind of like this thread. I have enjoyed the pictures though
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Dave Morgan chassis seminar a success [Re: Quicktree] #553104
12/18/09 09:09 AM
12/18/09 09:09 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Re: Dave Morgan chassis seminar a success [Re: Blown71X] #553105
12/18/09 10:28 AM
12/18/09 10:28 AM
gregsdart Offline
gregsdart  Offline
I have a hunch the reason many people believe in both methods is simple. The driveshaft to pinion measurement is seldom wrong due to the fact that most cars are built right to start with, with the shaft and engine centerline very close to right. Secondly, it takes a fare amount of improper angle to produce real problems with our type of equipment. The torque converter acts as a cushion, the tires act as a cushion.
I got my driveshaft education in the 60s , on a piece of equipment that would tear itself apart if you didn't get it close, or right.
A single U joint if run at an angle, and run at a steady speed, will produce a faster/slower motion twice per revolution. It is zero difference to very little at low angles, but grows rapidly as the angle gets further from correct. That is why they phase u joints, and why there are such things as constant velocity Ujoints
(shame on me, I just couldn't stay out of it!
Re: Dave Morgan chassis seminar a success [Re: gregsdart] #553106
12/18/09 12:02 PM
12/18/09 12:02 PM
Q
Q
why? you are absolutely correct in my opinion. but you can see my opinion doesn't mean much
Re: Dave Morgan chassis seminar a success [Re: mr2performance] #553107
12/18/09 12:03 PM
12/18/09 12:03 PM
Q
Q
why? if the data to back it was these then you would have no case
Re: Dave Morgan chassis seminar a success [Re: Blown71X] #553108
12/18/09 12:06 PM
12/18/09 12:06 PM
Q
Q
you wouldn't have anything to do if it stopped
Re: Dave Morgan chassis seminar a success [Re: Quicktree] #553109
12/18/09 12:37 PM
12/18/09 12:37 PM
Lebanon,IN
Lebanon,IN
"why? if the data to back it was these then you would have no case"
My "case"and or "data" comes from experience along with the timeslips to back it up... not some idea or drawing of what a "perfect" situation
should look like.
Mike
Re: Dave Morgan chassis seminar a success [Re: Quicktree] #553110
12/18/09 12:44 PM
12/18/09 12:44 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No, No, NO, it is because the rear end swings in an arc and the pinion angle constantly changes, so that makes the data useless. If the rear simply went up and down and the pinion maintained the same plane, you might have a case, but it does not work like that. And by the way, it would be easy to do. You check the pinion angle with the car static, then raise or lower the car in whatever increments, you want and check it again. You log all these measurements, relative to shock position. Now, when said car is running down the track and you read the shock sensors, you could know the pinion angle at every point on the track. If you had ever looked at any shock graphs, you would realize this number would change during the entire run. I have numerous cars with shock sensors, that I could do this on. Why have I not? Because as Mike said, it is useless information, would tell you absolutely nothing of value.
Monte
Re: Dave Morgan chassis seminar a success [Re: mr2performance] #553111
12/18/09 12:47 PM
12/18/09 12:47 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
should look like.
Mike
My thoughts extactly Mike,same as my thoughts about enginneers,they can draw a perfect Azzhole on paper,but can't make it poop.I can make it po a perfect pile everytime.
Re: Dave Morgan chassis seminar a success [Re: B G Racing] #553112
12/18/09 12:55 PM
12/18/09 12:55 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
should look like.
Mike
i gotta remember that line next time i deal with the engineer on my current project... thanks Bob
Re: Dave Morgan chassis seminar a success [Re: DJVCuda] #553113
12/18/09 01:09 PM
12/18/09 01:09 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
well, that was fun. looks like a new script in the works
Re: Dave Morgan chassis seminar a success [Re: Monte_Smith] #553114
12/18/09 01:12 PM
12/18/09 01:12 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
That was my whole point. To show that, so people would see having it exactly perfect all the time is impossible.
Re: Dave Morgan chassis seminar a success [Re: TS3303] #553115
12/18/09 03:28 PM
12/18/09 03:28 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Nice picture
Re: Dave Morgan chassis seminar a success [Re: B G Racing] #553116
12/18/09 03:58 PM
12/18/09 03:58 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Wow ^^^^^^^^^^^^^^^^
You all have made ROLMFAO
Re: Dave Morgan chassis seminar a success [Re: blown572dart] #553117
12/18/09 04:17 PM
12/18/09 04:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Jimmy,you have to be sharp and look for all those small subtle nuances that Jim sneaks in.Always look out side the box.
Re: Dave Morgan chassis seminar a success [Re: B G Racing] #553118
12/18/09 04:36 PM
12/18/09 04:36 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
what? who me? never!
there is no answer or resolution to this thread so we might as well have a little fun and keep it light hearted.
or sometimes inside the little box......
Re: Dave Morgan chassis seminar a success [Re: TS3303] #553119
12/18/09 04:39 PM
12/18/09 04:39 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
As Judge Judy says"he doesn't know if he afoot or on horseback. See you later,going to shop X-mas party,
