Paint under vinyl top? #551573
12/12/09 08:37 AM
12/12/09 08:37 AM
Fort Wayne,Indiana 46845
mopar 394 Offline OP
I know this has been covered before but couldn't find it. My vinyl top car is in primer and I wanted to know what the finish on the roof needs to be under the top. Is sealer ok to install the top over or can I use some single stage paint left over from the engine compartment? Or should I paint it base/clear with the rest of the car and do I need to rough it up? Thanks, Todd
Re: Paint under vinyl top? [Re: mopar 394] #551574
12/12/09 10:46 AM
12/12/09 10:46 AM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
Single stage will work just fine. You will need to sand the primer before shooting the paint,but there is no need to rough up the paint before installing the new vinyl.
Re: Paint under vinyl top? [Re: mopar 394] #551575
12/13/09 03:10 PM
12/13/09 03:10 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Just paint it base clear with the rest of the car and rough it up with scotchbrite or fine sandpaper before installing the top.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Paint under vinyl top? [Re: DPelletier] #551576
12/13/09 03:27 PM
12/13/09 03:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I can't wait to see the post were a "Mopar" guy/gal paints the car inside and out, top to bottom, engine bay, trunk, jambs, underside, hardtop or vinyl roof car, regardless of what gets covered up/over with trim, upholstrey etc,etc with the same "stage" of paint .....I've been painting cars for 30 years,.....and I'm amazed at the "Mopar mismash" of painting panels off the car, different "stages" of paint used in jambs, engine bays, trunks.... .....I don't get it?,...is it a $$$ factor?
Re: Paint under vinyl top? [Re: DAYCLONA] #551577
12/13/09 03:33 PM
12/13/09 03:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah, we're all really cheap.... Any paint under the vinyl top has to be better than what the factory did.. Just lay down a couple full wet coats so it's well sealed.... Paint it Pink, it'll be worth more..
Re: Paint under vinyl top? [Re: DAYCLONA] #551578
12/13/09 06:00 PM
12/13/09 06:00 PM
Jacksonville Florida
elitecustombody Offline
I'm with you on that one ,and I will probably never understand it either.
Re: Paint under vinyl top? [Re: elitecustombody] #551579
12/13/09 06:34 PM
12/13/09 06:34 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
I personally would never do it that way,but I can understand why some of these guy do.
Re: Paint under vinyl top? [Re: DPelletier] #551580
12/13/09 11:12 PM
12/13/09 11:12 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Why bother with the base, just clear right over the primer. Single stage without needing to get something else.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Paint under vinyl top? [Re: 1hot68] #551581
12/14/09 01:45 AM
12/14/09 01:45 AM
please help me understand,I want to know
Re: Paint under vinyl top? [Re: elitecustombody] #551582
12/14/09 08:39 AM
12/14/09 08:39 AM
SE Pa.
LimeliteAero Offline
SE Pa.
just taking a guess here but I think the people using the single stage paint in the jambs along with the front and rear compartments are guys doing some of the paint themselves then sending the car out to the pro to shoot the main body?
at least with me that was the case when the GTX was done.
Re: Paint under vinyl top? [Re: LimeliteAero] #551583
12/14/09 09:17 AM
12/14/09 09:17 AM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
Yep, thats just what I was thinking.
Re: Paint under vinyl top? [Re: CJK440] #551584
12/14/09 12:07 PM
12/14/09 12:07 PM
DPelletier Offline
DPelletier  Offline
Well, that would certainly work, but I just figured it was simpler to tell them to paint the whole car without trying to treat certain areas differently.......your car; your choices - mine got painted EVERYWHERE in base/clear.
Re: Paint under vinyl top? [Re: DPelletier] #551585
12/14/09 01:30 PM
12/14/09 01:30 PM
SE Pa.
SE Pa.
I would think with the cost of materials now it isnt practical to base/clear a roof that will be getting covered.
Re: Paint under vinyl top? [Re: LimeliteAero] #551586
12/14/09 01:44 PM
12/14/09 01:44 PM
DPelletier Offline
DPelletier  Offline
....In the big scheme of the $100k plus I've spent on this car, the extra $50 or $100 bucks worth of base coat to have color on the roof was negligible......but I see your point.
Cheers,
Re: Paint under vinyl top? [Re: DPelletier] #551587
12/14/09 07:59 PM
12/14/09 07:59 PM
Denver,NC
hemiheadNC Offline
hemiheadNC  Offline
Denver,NC
....dont EVER use POR 15 under a v-top....
I'm lost in the 60's and DAMN proud of it.
Re: Paint under vinyl top? [Re: hemiheadNC] #551588
12/14/09 08:02 PM
12/14/09 08:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
....dont EVER use POR 15....
Fixed it for ya!!
Re: Paint under vinyl top? [Re: 1_WILD_RT] #551589
12/14/09 08:05 PM
12/14/09 08:05 PM
Denver,NC
hemiheadNC Offline
hemiheadNC  Offline
Denver,NC
...thanks, you're right....sorry, brain drain on Monday....
