68-70 383/440 Magnum Exhaust Manifolds on C Body #551403
12/11/09 10:03 PM
12/11/09 10:03 PM
Virginia
mopars4life Offline OP
Virginia
Any issues wanting to use the nicer manifolds on a 1970 chrysler 300 wagon? Was originally a 383 car but now has a 440 and before the custom exhaust gets done, wanted better manifolds since no one makes decent affordable quality headers for it. Thanks
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: mopars4life] #551404
12/11/09 10:53 PM
12/11/09 10:53 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I don't think there would be any issues, but I haven't done that swap. The '70 rt side manifold flange where the exhaust pipe attaches has the 2 bolt locations rotated to a different position than the '68-'69, and the left side has a provision for intake heat on the '70 that the earlier ones don't.
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: topside] #551405
12/12/09 07:50 AM
12/12/09 07:50 AM
dart1962_440 Offline
I heard the Hedman shorties work on a C-body. I believe the p/n is 78070. $167.99 at Jegs. C-body Dry Dock guys could confirm. These may be an alternate solution.
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: mopars4life] #551406
12/12/09 09:18 AM
12/12/09 09:18 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I think you may be better off with some factory HP manifolds with a nice durable finsh on them.
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: dart1962_440] #551407
12/12/09 09:25 AM
12/12/09 09:25 AM
Virginia
Virginia
Thanks for the responses. The headers we've found to date are pretty cheap/universal and we can't afford custom headers to so we are trying to stick with the freer flowing factory manifolds. Sounds like the 1970's might be better but may be more pricey.
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: mopars4life] #551408
12/12/09 10:02 AM
12/12/09 10:02 AM
Commando1 Offline
Commando1  Offline
This is in the classifieds as we speak...
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: Commando1] #551409
12/12/09 07:06 PM
12/12/09 07:06 PM
Virginia
Virginia
Saw that but he only has the drivers side.
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: mopars4life] #551410
12/12/09 10:12 PM
12/12/09 10:12 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
thats all you need since passenger side is same as a b or e body.
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: 05dakota] #551411
12/13/09 11:50 AM
12/13/09 11:50 AM
Central NC
gch Offline
gch  Offline
Central NC
Hedman shorties work well on a c body.You need the small starter though.
Any pass manifold will work.Drivers side is C body specific.Outlet position may vary from year to year but will work.
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: gch] #551412
12/13/09 04:19 PM
12/13/09 04:19 PM
Riverside, Iowa
carmak Offline
carmak  Offline
Riverside, Iowa
I know it's OT but do you have any pics of the 300 wagon? It sound very cool.
Carmak
Riverside, Iowa
Re: 68-70 383/440 Magnum Exhaust Manifolds on C Body [Re: carmak] #551413
12/14/09 04:30 PM
12/14/09 04:30 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
The 69-71 C-body HP manifold is specially-curved to fit around the steering column and the rubber coupler. Although the 67-68 B-manifold fits on the driverside of a Slabside, I'd be skeptical how well a B-manifold would fit on a Fusey.
Teh Fusey also lists different manifolds between 383 and 440 whereas it didn't in earlier years IIRC. Might be related.
If it were me, I'd give the Hedman shorties a try. I have them on a 68 and I love them!
http://www.cbodydrydock.com/forum_viewtopic.php?6.22001
