School me on 2-3/4" front B/E body calipers... #550751
12/11/09 02:30 AM
12/11/09 02:30 AM
WA 98043
thecarfarmer Offline OP
WA 98043
My truck is down at Scarebird's shop, where Mark is dreaming up a disc conversion.
It looks like it will likely use a Ford rotor and E-body calipers.
So, here's my question: looking at the caliper list in the tech archives, there are a number of calipers which have the same 2.75" piston diameter as the 70-72 B-body and 70-74 E-body caliper. The 73-5 B-body and the F-M-J series cars had the same size piston; will these calipers interchange?
Thanks all!
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: School me on 2-3/4" front B/E body calipers... [Re: thecarfarmer] #550752
12/11/09 03:52 AM
12/11/09 03:52 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If it's still a pin style caliper it will bolt on, if it's the other style a different caliper adapter will bolt to the same spindle... The flex hose also changed from a thread in style to a banjo bolt style...
Re: School me on 2-3/4" front B/E body calipers... [Re: 1_WILD_RT] #550753
12/11/09 10:15 AM
12/11/09 10:15 AM
as said some are pin and some are sliders. the hose mounting location MAY be different on different apps of the same type (both sliders and pin types)
