valve lash quickie #546379
12/05/09 07:25 PM
12/05/09 07:25 PM
wine valley
cudaben1968 Offline OP
wine valley
440 engine, solid roller cam with roller rockers 1.5 ratio.... ball park what lash i need on the valve
Half measures availed us nothing. We stood at the turning point. -Alcoholics Anonymous, The Big Book
Re: valve lash quickie [Re: cudaben1968] #546380
12/05/09 07:57 PM
12/05/09 07:57 PM
owt west
Thread Ender1 Offline
owt west
Id ruff it in with .022 to .024 to get by with.
Re: valve lash quickie [Re: Thread Ender1] #546381
12/05/09 10:59 PM
12/05/09 10:59 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Thats a good lash to start with for aluminum heads cold. thats what I use.
Re: valve lash quickie [Re: cudaben1968] #546382
12/05/09 11:02 PM
12/05/09 11:02 PM
Do you have any idea which cam company made it and what grind? Solid roller cams can have anywhere from .032 to .012 hot There is no way I would risk taking a chance on using a S.W.A.G on what lash to use on a cam I knew nothing about several ways to find out which cam and grind it is, pull the cam out and look for the grind and companys name on the front or the rear of the cam, or take it out and take it to a shop that has a Cam Doctor or send it to a shop that has a Cam Docter and have them check it for lift, duration and hot valve lash settings
Re: valve lash quickie [Re: Cab_Burge] #546383
12/06/09 12:06 AM
12/06/09 12:06 AM
UK
602heavy Offline
602heavy  Offline
UK
Measure the lash ramp............put a dial gauge on the lifter/pushrod , between zero lift to when the dial gauge starts to spin crazy will be you're lash setting x rocker ratio , ie: if the lash ramp measures .010" the lash with 1.5 rr will be .010" x 1.5 = .015" lash cold.
As Cab says , guessing lash will break valve trains in a short space of time , you might get away with tighter lash , anything much over .004" lash is asking for trouble.
Re: valve lash quickie [Re: cudaben1968] #546384
12/06/09 02:34 PM
12/06/09 02:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
For what it`s worth, I set mine at .014-.016 cold w/alum heads and they end up around .020-.022 hot....Isky solid roller.
Re: valve lash quickie [Re: Thumperdart] #546385
12/06/09 02:37 PM
12/06/09 02:37 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
again you need to know what the cam company recommends. I set my at .005-.007 cold, and it opens to .020-.022 hot...aluminum engine and Jesel rocker arms.
Re: valve lash quickie [Re: Bob_Coomer] #546386
12/07/09 10:14 PM
12/07/09 10:14 PM
wine valley
wine valley
i cant find the specs i need.... but its an isky cam and iron block with aluminum heads so would 15 be good???
Re: valve lash quickie [Re: cudaben1968] #546387
12/08/09 01:36 AM
12/08/09 01:36 AM
how old is the Isky cam? They use to be real loose on the lash, .028 hot on most of the ones I know about I would probally try .020 cold and reset it as soon as possible. Check Isky web site for the lash, can you measure the valve opening and duration? If so that might get you close on the valve lift to see what cam it is close to. Best bet is to remove it and make sure which brand and what grind it is
Re: valve lash quickie [Re: Cab_Burge] #546388
12/11/09 02:22 AM
12/11/09 02:22 AM
wine valley
wine valley
i called isky and gave them close to the cam specs i remembered, he found the cam and yes its 28. thanks
