valve lash quickie
#546379
12/05/09 08:25 PM
12/05/09 08:25 PM
Posts: 388 wine valley
cudaben1968
wine valley
440 engine, solid roller cam with roller rockers 1.5 ratio.... ball park what lash i need on the valve
Half measures availed us nothing. We stood at the turning point.
-Alcoholics Anonymous, The Big Book
Re: valve lash quickie
[Re: cudaben1968]
#546382
12/06/09 12:02 AM
12/06/09 12:02 AM
Posts: 43,206 Bend,OR USA
Cab_Burge
Do you have any idea which cam company made it and what grind? Solid roller cams can have anywhere from .032 to .012 hot There is no way I would risk taking a chance on using a S.W.A.G on what lash to use on a cam I knew nothing about several ways to find out which cam and grind it is, pull the cam out and look for the grind and companys name on the front or the rear of the cam, or take it out and take it to a shop that has a Cam Doctor or send it to a shop that has a Cam Docter and have them check it for lift, duration and hot valve lash settings
[Re: cudaben1968]
#546384
12/06/09 03:34 PM
12/06/09 03:34 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
For what it`s worth, I set mine at .014-.016 cold w/alum heads and they end up around .020-.022 hot....Isky solid roller.
[Re: Thumperdart]
#546385
12/06/09 03:37 PM
12/06/09 03:37 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
again you need to know what the cam company recommends. I set my at .005-.007 cold, and it opens to .020-.022 hot...aluminum engine and Jesel rocker arms.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#546386
12/07/09 11:14 PM
12/07/09 11:14 PM
cudaben1968
wine valley
i cant find the specs i need.... but its an isky cam and iron block with aluminum heads so would 15 be good???
[Re: Cab_Burge]
#546388
12/11/09 03:22 AM
12/11/09 03:22 AM
cudaben1968
wine valley
i called isky and gave them close to the cam specs i remembered, he found the cam and yes its 28. thanks
