Re: 302 heads on a 1970 340?
[Re: Reggie]
#545997
12/05/09 03:25 PM
12/05/09 03:25 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
are you showing .074" above deck, or .026" below? if they're above deck, you're stuck with open chambered heads. if they're below, I'd get these enginequests or these RHS heads from hughes.... the enginequests will require magnum style rockers (~40-50 used, $80 new for stockers), the RHS's use stock LA rocker gear. OOTB hughes has found an LA head with 2.02's (576 castings) flow ~212 cfm@ .500 lift, the EQ's flow 227, (with the smaller 1.92" valve) and the RHS X heads 252 CFM at the same lift...302 heads typically flow 135-160cfm on the intake side, and max out fully ported at about 140 on the exhaust...
[Re: Dakota_Don]
#546001
12/05/09 09:30 PM
12/05/09 09:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The only way a 302 or magnum will work is if you can find a really thick head gasket to keep your piston and head at least .030 inches apart, if they are more than .020 out of the block then good luck with that Other than that you can change pistons also. A max ported 302 with big valves can make more power than a bone stock X head but not much
