302 heads on a 1970 340? #545993
12/05/09 02:24 PM
12/05/09 02:24 PM
Germany, Northcoast
Buschi340 Offline OP
Germany, Northcoast
Hi,
I'm thinking about some "new" heads for my 340 since my J's do have too much play in the valve guides. The rebuilt costs and an offer for these heads are the same.
What do you guys think? Is it worth it or not?
See attached a picture years ago with the TRW pistons at TDC....
Re: 302 heads on a 1970 340? [Re: Buschi340] #545994
12/05/09 02:36 PM
12/05/09 02:36 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The 302 heads are 318 small port i think, they would be a step backwards. best bet would be a set of the RHS X heads all done and shipped to you.
Re: 302 heads on a 1970 340? [Re: ademon] #545995
12/05/09 02:40 PM
12/05/09 02:40 PM
Germany, Northcoast
Germany, Northcoast
yes, they are for 318. But closed chamber, swirl port. To modify a 318 it is the first choice. But on a 340 as well?
Re: 302 heads on a 1970 340? [Re: Buschi340] #545996
12/05/09 02:49 PM
12/05/09 02:49 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
302s will choke your 340. They are closed chamber, but they have smaller 1.78"/1.50" valves compared to the 340s 2.02"/1.60" valves. Not a good idea IMHO.
Re: 302 heads on a 1970 340? [Re: Reggie] #545997
12/05/09 03:25 PM
12/05/09 03:25 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
are you showing .074" above deck, or .026" below?
if they're above deck, you're stuck with open chambered heads.
if they're below, I'd get these enginequests or these RHS heads from hughes....
the enginequests will require magnum style rockers (~40-50 used, $80 new for stockers), the RHS's use stock LA rocker gear.
OOTB hughes has found an LA head with 2.02's (576 castings) flow ~212 cfm@ .500 lift, the EQ's flow 227, (with the smaller 1.92" valve) and the RHS X heads 252 CFM at the same lift...302 heads typically flow 135-160cfm on the intake side, and max out fully ported at about 140 on the exhaust...
2017 Grand Cherokee Overland
Re: 302 heads on a 1970 340? [Re: patrick] #545998
12/05/09 06:07 PM
12/05/09 06:07 PM
Germany, Northcoast
Germany, Northcoast
oh yes, you are right. Pistons are slightly above deck. I totally forgot that.So I can't use these 302's.
Re: 302 heads on a 1970 340? [Re: Buschi340] #545999
12/05/09 06:43 PM
12/05/09 06:43 PM
your staying w open chambered heads but might plug your specs into here. http://kb-silvolite.com/calc.php? to stay on top of what your CR will be.
Re: 302 heads on a 1970 340? [Re: Buschi340] #546000
12/05/09 07:12 PM
12/05/09 07:12 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
no way, go magnum
Re: 302 heads on a 1970 340? [Re: Dakota_Don] #546001
12/05/09 09:30 PM
12/05/09 09:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The only way a 302 or magnum will work is if you can find a really thick head gasket to keep your piston and head at least .030 inches apart, if they are more than .020 out of the block then good luck with that
Other than that you can change pistons also.
A max ported 302 with big valves can make more power than a bone stock X head but not much
