hemi pushrod problems #544930
12/04/09 03:44 PM
12/04/09 03:44 PM
bc canada
dbailey43 Offline OP
bc canada
my 472" mopar engines west hemi has smoked a couple of rocker end pushrod cups twice,oiling doesn't seem to be an issue,could my comp cam roller specs be in error for my alum mopar head combo(.026")
Re: hemi pushrod problems [Re: dbailey43] #544931
12/04/09 05:03 PM
12/04/09 05:03 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
What push rods are you using? What sort of spring pressure? Street use with lots of idling? How many threads are showing bellow the rocker? What type of rockers are they? Oil from the cam bearing the block, or push rods? Groove in number 4 cam bearing?
Re: hemi pushrod problems [Re: torkrules] #544932
12/04/09 05:27 PM
12/04/09 05:27 PM
bc canada
bc canada
smith brothers pushrods sorry lost info on roller tipped rockers,cam and kit all from comp,.692 lift cam,wish i knew all other info,engine buidler happy to take my money!only used car for bracket competition,maybe 30 passes,was happy with 10.60 time with 3600# car.
Re: hemi pushrod problems [Re: torkrules] #544933
12/04/09 05:31 PM
12/04/09 05:31 PM
bc canada
bc canada
oiling external from pressure fitting,pushrods solid
Re: hemi pushrod problems [Re: dbailey43] #544934
12/04/09 05:53 PM
12/04/09 05:53 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
I had burnt a couple of exhaust pushrods and adjusters on my 528 Hemi I built a few years ago. I was running a solid lifter cam with dual valve springs and Indy roller rockers. It was evident that the adjuster and pushrod tips were not getting oil. I had Smith Bros send me the same pushrods, only with holes in the tips so the lifters would oil the tips and that solved my problems. I guess if you are running a roller cam you might have excessive spring pressure or a need for a spray bar oiling system. Duster Dave had the specs somewhere on here for the spray oiling system he made.
Re: hemi pushrod problems [Re: dbailey43] #544935
12/04/09 06:47 PM
12/04/09 06:47 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
The extra spring pressure for the solid roller plus the amount of cam lift and idling can cause push rod problems. Push rod oiling will solve the problem, however you will need lifters that provide oil in this fashion plus push rods with holes in the ball and cup. Also, without bushed lifter bores you need some type of restrictor in the pushrod (.020-.030) otherwise the head will flood with oil.
Some things to check. Make sure no more than 2 threads are showing bellow the rocker. Check the rockers and make sure they have holes that direct oil at the pushrod tip. Some roller rockers do not have this. A groove in the bushing near the pushrod oil hole (in the rocker) is a good idea too. Make sure there is no restrictor in the block (unless it's a word block). Sometimes making the groove in number 4 cam bearing will help get a little more oil to the rockers.
Re: hemi pushrod problems [Re: torkrules] #544936
12/04/09 06:58 PM
12/04/09 06:58 PM
bc canada
bc canada
really appreciate responses,would like to get that spray solution.have checked rocker potential for problem and all looks well,will check seat pressure and quote numbers,maybe someone will know if they are too high!
Re: hemi pushrod problems [Re: dbailey43] #544937
12/04/09 10:07 PM
12/04/09 10:07 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Were they intake or exhaust?
Same ones each time?
What rockers are you using?
How did the adjusters look and did you replace any of those either time?
Re: hemi pushrod problems [Re: SSAAHemiFan] #544938
12/04/09 10:11 PM
12/04/09 10:11 PM
bc canada
bc canada
exhaust: replaced adjusters and rods,am in dark as to whose rockers they are,only that they look tough and have roller tips!
Re: hemi pushrod problems [Re: dbailey43] #544939
12/04/09 10:17 PM
12/04/09 10:17 PM
bc canada
bc canada
pair of rods smoked on driver's bank near rear first time,repeat exhaust other bank on second occasion,also second last cylindar at rear,changed adjusters both times ,they were starting to "blue",cup ends pushrods ,Three real blue one shattered
Re: hemi pushrod problems [Re: dbailey43] #544940
12/05/09 09:18 AM
12/05/09 09:18 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Are the steel? Do they have any markings (the Landy rockers have "DLI" sort of like a circle on top of them.
Re: hemi pushrod problems [Re: torkrules] #544941
12/05/09 10:27 AM
12/05/09 10:27 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Buy external oiling do you mean the heads are oiled by external lines to the heads instead of up thru the block?
Are you using head studs or bolts?
Suds can sometimes restrict oil flow thru the stand and a external line may have a restrictor in the circuit that you might not be aware of.
Can you get a pic of the rockers and stands?
That may help figure out where you are at. Some rockers do have some oiling issues.
You have to really check the fit of the rockers, shafts and stands and there relationship to the oiling hole's - there is sometimes just enough slop or tolerance stackup to cause a partial blockage of some of these holes.
Or if you don't want to get into all of that just prime the oil pump and watch the oiling at each position.
It is very time consuming but you may be suprised at what you find.
Re: hemi pushrod problems [Re: SSAAHemiFan] #544942
12/05/09 11:49 AM
12/05/09 11:49 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
dbailey43 here are a few pix of what indy roller rockers look like.
Re: hemi pushrod problems [Re: Hemi_Ram] #544943
12/05/09 11:51 AM
12/05/09 11:51 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Another pix
Re: hemi pushrod problems [Re: Hemi_Ram] #544944
12/05/09 12:23 PM
12/05/09 12:23 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Another
Re: hemi pushrod problems [Re: Snoopy] #544945
12/05/09 01:38 PM
12/05/09 01:38 PM
bc canada
bc canada
my rockers look the identical as your pictures also have same anodized shaft stands,heads are clamped with studs. and ahain thanks
Re: hemi pushrod problems [Re: dbailey43] #544946
12/05/09 01:42 PM
12/05/09 01:42 PM
bc canada
bc canada
rocker shafts externally oiled thru back of heads,if there is oil flow restrictors in that system where will i locate them?
