Re: hemi pushrod problems
[Re: dbailey43]
#544931
12/04/09 05:03 PM
12/04/09 05:03 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
my 472" mopar engines west hemi has smoked a couple of rocker end pushrod cups twice,oiling doesn't seem to be an issue,could my comp cam roller specs be in error for my alum mopar head combo(.026")
What push rods are you using? What sort of spring pressure? Street use with lots of idling? How many threads are showing bellow the rocker? What type of rockers are they? Oil from the cam bearing the block, or push rods? Groove in number 4 cam bearing?
[Re: dbailey43]
#544935
12/04/09 06:47 PM
12/04/09 06:47 PM
torkrules
I'm neurotic
I'm neurotic
oiling external from pressure fitting,pushrods solid
The extra spring pressure for the solid roller plus the amount of cam lift and idling can cause push rod problems. Push rod oiling will solve the problem, however you will need lifters that provide oil in this fashion plus push rods with holes in the ball and cup. Also, without bushed lifter bores you need some type of restrictor in the pushrod (.020-.030) otherwise the head will flood with oil.
Some things to check. Make sure no more than 2 threads are showing bellow the rocker. Check the rockers and make sure they have holes that direct oil at the pushrod tip. Some roller rockers do not have this. A groove in the bushing near the pushrod oil hole (in the rocker) is a good idea too. Make sure there is no restrictor in the block (unless it's a word block). Sometimes making the groove in number 4 cam bearing will help get a little more oil to the rockers.
[Re: dbailey43]
#544940
12/05/09 09:18 AM
12/05/09 09:18 AM
torkrules
I'm neurotic
I'm neurotic
exhaust: replaced adjusters and rods,am in dark as to whose rockers they are,only that they look tough and have roller tips!
Are the steel? Do they have any markings (the Landy rockers have "DLI" sort of like a circle on top of them.
