wont crank!! and stuff...... #542625
12/02/09 12:15 AM
12/02/09 12:15 AM
wine valley
cudaben1968 Offline OP
wine valley
Just playing with my barracuda and have been trying to fix some wiring issues that some idiot(me) has created over the last 11 years. here is my problem maybe somebody or everybody can help out.
Its a 68 cuda with a 440/540 now has msd 6al, 93 toyota alt(internally regulated), batt in the trunk, and a hack job of wiring. so here is my issue. i just replaced my started relay b/c it was busted. i have power to it from the batt. and the neutral saftey switch is hooked up and i checked for continuity and its good, the yellow wire from the relay to the ign swtch is good too. and when i turn the ign switch i get 12 or 13 volts at the yellow ign wire at the relay. but it wont crank. if i jump the hot post to the starter sol. it will kick over. but not by the key.... any ideas?
and with the batt in the trunk do i run my alt power straight back to the opp side of the batt kill switch or to the battery itself?
also with msd 6al can i get rid of my ballast resistor? if so what do i do with the four wires on it?
Half measures availed us nothing. We stood at the turning point. -Alcoholics Anonymous, The Big Book
Re: wont crank!! and stuff...... [Re: cudaben1968] #542626
12/02/09 02:45 AM
12/02/09 02:45 AM
Cab_Burge Online work
Cab_Burge  Online Work
Is the ground wire from the transmission nuetral switch hooked up and functioning correctly?
Re: wont crank!! and stuff...... [Re: cudaben1968] #542627
12/02/09 08:49 AM
12/02/09 08:49 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Make sure you don't don't have the crank and nutral safety wires on the wrong posts.
If you ground the neutral safety post it should start with the key. If so something is wrong with the safety switch or wiring.
With MSD ignition you can toss the ballast resistor. Just tape the ends to the harness so they aren't hanging down, until you get a chance to rewire the car. If stock ignition isn't being used the ballast resistor does nothing.
The alt wire needs to go to the battery or the battery side of the switch. If you put it to the on side of the switch the car will never shut off with the emergency safety switch. Or if you don't feel like running the heavy alt wire all the way back there just run your hot ignition wire back there and attach it to the small on post(this option will only work if you have a 4 post switch)...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: wont crank!! and stuff...... [Re: cudaben1968] #542628
12/02/09 10:25 AM
12/02/09 10:25 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The starter relay has to be well grounded, too...
Re: wont crank!! and stuff...... [Re: Sixpak] #542629
12/03/09 12:27 AM
12/03/09 12:27 AM
wine valley
wine valley
ok well thanks guys.
im thinking that my problem lies with the neutral safety switch.... hmmmm. i went to buy a new one and all they had were three post switches. mine is a single. anyone know what i can get that?
Re: wont crank!! and stuff...... [Re: cudaben1968] #542630
12/03/09 12:31 AM
12/03/09 12:31 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
HUH?
SDG Motorsports
Re: wont crank!! and stuff...... [Re: cudaben1968] #542631
12/03/09 12:35 AM
12/03/09 12:35 AM
Santa Rosa,CA USA
67dodgeracer Offline
Santa Rosa,CA USA
The three post will work,the center post is for the neutral safety wire.
Re: wont crank!! and stuff...... [Re: 67dodgeracer] #542632
12/03/09 12:47 AM
12/03/09 12:47 AM
wine valley
wine valley
where do the back up lights work from? and my neutral switch is a threaded single post. so just make a push on type plug for it then?
Re: wont crank!! and stuff...... [Re: cudaben1968] #542633
12/03/09 12:55 AM
12/03/09 12:55 AM
Santa Rosa,CA USA
Santa Rosa,CA USA
I believe a simple female bullet type wire connector will work fine.Don't remember which is for the backup,sorry.
Re: wont crank!! and stuff...... [Re: 67dodgeracer] #542634
12/03/09 02:58 AM
12/03/09 02:58 AM
The early cars before the three post nuetral switch and a switch on the colum for the back up lights. The center post is the nuetral switch and the other two are for the back up lights on the later cars. There are two different lengths of the center post switches for the early and ancient cars, what year is yours?
