Removing the drivetrain out the bottom.... #541996
12/01/09 03:22 PM
12/01/09 03:22 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Pictures, advice, anything related is much appreciated.
I know it's way easier than lifting the drivetrain out, but can it be done with a 1-ton cherry picker alone?
Re: Removing the drivetrain out the bottom.... [Re: sharpie] #541997
12/01/09 04:14 PM
12/01/09 04:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have not done it yet, but the pics I have seen usually involve removing the front bumper and running a chain around the bumper brackets. Some guys have made steel tube extensions that bolt up in place of the bumper brackets.
You will need a cart of some sort to lower the engine onto. Dig up Cameron's thread about his 360 magnum installation he was working on for pics.
Re: Removing the drivetrain out the bottom.... [Re: sharpie] #541998
12/01/09 04:51 PM
12/01/09 04:51 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Re: Removing the drivetrain out the bottom.... [Re: sharpie] #541999
12/01/09 04:57 PM
12/01/09 04:57 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Are you sure its way easier to come out the bottom? Seems to me when its all said and done its more fasteners or work. I pulled out a 383 just the other day and it couldnt have been much easier. The only other stuff holding in the tranny was the cross member assy, which you will have to remove any ways. Do you plan to split the motor and tranny apart?
Re: Removing the drivetrain out the bottom.... [Re: sharpie] #542000
12/01/09 04:59 PM
12/01/09 04:59 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
We did it with our Dart when we swapped from a 225 to a 360, just as an experiment.
We had to swap K-frames anyway, and it was easier than I thought it would be to go from the bottom.
Re: Removing the drivetrain out the bottom.... [Re: CYACOP] #542001
12/01/09 05:17 PM
12/01/09 05:17 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
More fasteners, but better for what I need to do. I need to replace the steering box and the transmission seals (front, pump, rear), and paint the motor anyway. The steering box would necessitate taking out the driver's side header (it's an A-body) and lifting the engine, so I might as well take out the engine since I need to do the other stuff.
Re: Removing the drivetrain out the bottom.... [Re: sharpie] #542002
12/01/09 05:33 PM
12/01/09 05:33 PM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
Once everything is disconnected it's just 8 bolts. Here is a shot of mine coming out from the bottom. This was the first time I did it this way and it was much easier then going out the top. Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: Removing the drivetrain out the bottom.... [Re: FJ6AAR] #542003
12/01/09 05:34 PM
12/01/09 05:34 PM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
One more....
Re: Removing the drivetrain out the bottom.... [Re: sharpie] #542004
12/01/09 05:39 PM
12/01/09 05:39 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Here's mine
Re: Removing the drivetrain out the bottom.... [Re: sharpie] #542005
12/01/09 06:04 PM
12/01/09 06:04 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
I would still just pull the motor and reseal the tranny in place and that will give you access to the steering box. The above pic shows a car lift, I dont think you have but a cherry picker.
Re: Removing the drivetrain out the bottom.... [Re: CYACOP] #542006
12/01/09 06:33 PM
12/01/09 06:33 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Just did another one from the bottom yesterday. I'll download some pics from the BB in a minute or so...
Re: Removing the drivetrain out the bottom.... [Re: Neil] #542007
12/01/09 07:10 PM
12/01/09 07:10 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
No need to pull the bumper off or rig up anything of the sort. There is usually a 1" hole on the bottom of each frame rail near the radiator support. Just use a chain with a hook on each end, insert the hook in the hole, and you're good to go.
