Lowering Links For Leaf Spring Suspension #541617
12/01/09 01:21 AM
12/01/09 01:21 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I was on here a long time ago and I seen someone come out with links that gave you the option of raising the rear 1", lowering the rear 1", or lowering the rear 2" on a leaf spring suspension. Are these still available and who makes them?
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Lowering Links For Leaf Spring Suspension [Re: knyech1] #541618
12/01/09 07:36 AM
12/01/09 07:36 AM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Here's a bump for ya
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: Lowering Links For Leaf Spring Suspension [Re: rockerbob] #541619
12/01/09 07:46 AM
12/01/09 07:46 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
they sell lowering blocks at auto zone
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Lowering Links For Leaf Spring Suspension [Re: StripeHOG] #541620
12/01/09 09:36 AM
12/01/09 09:36 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
AFCO sliders in place of the rear shackles is what I use. Depending on shackle length it will lower it at least an inch.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Lowering Links For Leaf Spring Suspension [Re: 67HEMI] #541621
12/01/09 10:33 AM
12/01/09 10:33 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
I think he is referring to the front hangers with multiple mount holes...
...and I can't remember where I saw them either.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Lowering Links For Leaf Spring Suspension [Re: 67Charger] #541622
12/01/09 11:19 AM
12/01/09 11:19 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Lowering Links For Leaf Spring Suspension [Re: 67Charger] #541623
12/01/09 09:54 PM
12/01/09 09:54 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
yes I am
and the link above not sure that is them, I thought there were more holes than that but maybe not...
Re: Lowering Links For Leaf Spring Suspension [Re: knyech1] #541624
12/01/09 11:18 PM
12/01/09 11:18 PM
megajoltman Offline
megajoltman  Offline
yes I am
I know I have seen one with 3 holes in it somewhere on the web can't seem find it
Procharged 350Z
Re: Lowering Links For Leaf Spring Suspension [Re: megajoltman] #541625
12/02/09 12:05 AM
12/02/09 12:05 AM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
When I built my car, I drilled an extra set of holes in the front spring box just for that purpose.
My question is, would lowering the rear (generally speaking) have a tendency to help or hurt my launch? This will have the effect of giving my bottom 4-link bar a slight downward angle. Any thoughts?
Re: Lowering Links For Leaf Spring Suspension [Re: bill_greenwood] #541626
03/20/10 01:43 PM
03/20/10 01:43 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I wanna know too
Re: Lowering Links For Leaf Spring Suspension [Re: bill_greenwood] #541627
03/20/10 02:26 PM
03/20/10 02:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In theory it would be lowering the IC which normally
gives you a shofter hit on the tire but increases the
length of time it hits the tire
EDIT
with doing just the lowering holes on the front you
really arent lowering the IC, your just lowering
the body some(the front spring bolt is still in the
same position as before) but you will have lowered
the rear of the body which should have made it easier
for the front to transfer the weight to the rear
(the CG would by rights have been moved up slightly)
Re: Lowering Links For Leaf Spring Suspension [Re: MR_P_BODY] #541628
03/20/10 06:15 PM
03/20/10 06:15 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
EDIT
Lowering the front spring eye bolt height would be lowering the IC.
Also it will be raising the body of the car. You would have to bring the bolt above the factory bolt height to lower the body.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Lowering Links For Leaf Spring Suspension [Re: F1Scamp] #541629
03/20/10 06:39 PM
03/20/10 06:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lowering the front bolt would lower the IC if you really
were lowering it BUT in this case you really arent,
its still in the same position in relation to the diff,
the IC is measured from the C/L of the diff and from
the ground, the spring arch didnt change when its
put in a upper or lower hole... it would be true if
this were actually a ladder bar
Re: Lowering Links For Leaf Spring Suspension [Re: MR_P_BODY] #541630
03/20/10 07:09 PM
03/20/10 07:09 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Have a diagram to show what you are saying? I have a couple of diagrams showing it is measured from the front of contact patch through the front of the spring bolt.?
Re: Lowering Links For Leaf Spring Suspension [Re: F1Scamp] #541631
03/20/10 07:14 PM
03/20/10 07:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have a diagram of what... how the IC is measured?
Re: Lowering Links For Leaf Spring Suspension [Re: F1Scamp] #541632
03/20/10 07:15 PM
03/20/10 07:15 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
I made this horrible paint image to show what I meant. Am I wrong?
Re: Lowering Links For Leaf Spring Suspension [Re: F1Scamp] #541633
03/20/10 07:19 PM
03/20/10 07:19 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
my impression is if you lower the front spring bolt mount.
you are lowering the I/C...
(your raising the rear of the car..)
and your changing slightly the pinion angle.
if you wanted to lower the rear ride height
youd have to raise the front spring bolt mount
or you could put sliders on the rear of the spring..and lower the car..
but moveing either end of the spring will move I/C
the rear sliders effectively move the front spring eye down..when the chassis it self lowers.
the tire stay put..so the angle from tire to front spring mount still moves..
cheaspt.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Lowering Links For Leaf Spring Suspension [Re: F1Scamp] #541634
03/20/10 07:21 PM
03/20/10 07:21 PM
the only factor that i see may need to be addressed with this picture is
if you choose the upper hole in the diagram
you would have to adjust (lower) the position of the box/square in that drawing to account for the lower ride height..
cheapst.
[image][/image]
Re: Lowering Links For Leaf Spring Suspension [Re: F1Scamp] #541635
03/20/10 07:25 PM
03/20/10 07:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well it doesnt have anything to do with the bottom of
the tire when you measure the IC... first in a ladder
bar or a leaf spring you cant change the length of
the IC, a ladder bar you can change the height of the
IC, but in a leaf spring you cant UNLESS you change
the arch of the spring where it would set up higher
or lower, but in the case here the arch didnt change
so the front bolt is still in the same height with
relationship to the diff... all that happened in this
case is the body moved up or down
Re: Lowering Links For Leaf Spring Suspension [Re: MR_P_BODY] #541636
03/20/10 07:31 PM
03/20/10 07:31 PM
double check that MrP..
the reason i say this..is ..
if you take that diagram and measure the distance from the center of the axle
to the lower hole
then to the middle hole
then the top hole..
you will find the top holes distance will be the longer/longest distance of the three positions.
unless you drill the three holes along a radius from the center axle..(not as shown...as shown its running in a straigh verticle line..)
so you would either have to move the Box/chassis down...
to reach the spring bolt
or
raise the center line of the axle ..again...so the spring bolt will reach the hole.
this will inevitably change the three points that factor to find I/C
the only point (of the three) that doesnt move is the bottom of the tire..as it is setting on the ground...
and its relation ship to the axle centerline as these two points are determined by tire diameter..but i dirgress
cheapst
[image][/image]
