Lowering Links For Leaf Spring Suspension
#541617
12/01/09 01:21 AM
12/01/09 01:21 AM
Posts: 486 IL
knyech1
IL
I was on here a long time ago and I seen someone come out with links that gave you the option of raising the rear 1", lowering the rear 1", or lowering the rear 2" on a leaf spring suspension. Are these still available and who makes them?
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Lowering Links For Leaf Spring Suspension
[Re: StripeHOG]
#541620
12/01/09 09:36 AM
12/01/09 09:36 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
AFCO sliders in place of the rear shackles is what I use. Depending on shackle length it will lower it at least an inch.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#541621
12/01/09 10:33 AM
12/01/09 10:33 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
I think he is referring to the front hangers with multiple mount holes... ...and I can't remember where I saw them either. ![](/ubbthreads/images/graemlins/laugh2.gif)
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#541623
12/01/09 09:54 PM
12/01/09 09:54 PM
Posts: 486 IL
knyech1
IL
yes I am
and the link above not sure that is them, I thought there were more holes than that but maybe not...
[Re: F1Scamp]
#541632
03/20/10 07:15 PM
03/20/10 07:15 PM
Posts: 419 NY
F1Scamp
NY
I made this horrible paint image to show what I meant. Am I wrong?
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: F1Scamp]
#541633
03/20/10 07:19 PM
03/20/10 07:19 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
my impression is if you lower the front spring bolt mount. you are lowering the I/C... (your raising the rear of the car..) and your changing slightly the pinion angle.
if you wanted to lower the rear ride height youd have to raise the front spring bolt mount or you could put sliders on the rear of the spring..and lower the car.. but moveing either end of the spring will move I/C the rear sliders effectively move the front spring eye down..when the chassis it self lowers. the tire stay put..so the angle from tire to front spring mount still moves.. cheaspt.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: F1Scamp]
#541635
03/20/10 07:25 PM
03/20/10 07:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well it doesnt have anything to do with the bottom of the tire when you measure the IC... first in a ladder bar or a leaf spring you cant change the length of the IC, a ladder bar you can change the height of the IC, but in a leaf spring you cant UNLESS you change the arch of the spring where it would set up higher or lower, but in the case here the arch didnt change so the front bolt is still in the same height with relationship to the diff... all that happened in this case is the body moved up or down ![](/ubbthreads/images/graemlins/wave.gif)
