Hemi Piston ? #540470
11/29/09 06:29 PM
11/29/09 06:29 PM
Odessa, Fl
blowndart Offline OP
Odessa, Fl
Does anyone make an off the shelf piston for a 4.28 bore and 4.375 stroke hemi? I can't seem to find one.
Re: Hemi Piston ? [Re: blowndart] #540471
11/29/09 06:33 PM
11/29/09 06:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have a new set of JE 4.375s 9:1 for a 4.15 stroke I would probably sell
Re: Hemi Piston ? [Re: blowndart] #540472
11/29/09 06:42 PM
11/29/09 06:42 PM
for how much compression with which heads? (chamber size)
Re: Hemi Piston ? #540473
11/29/09 07:03 PM
11/29/09 07:03 PM
Odessa, Fl
Odessa, Fl
9.0:1-10.5:1 CR with stock type iron heads.
Re: Hemi Piston ? [Re: blowndart] #540474
11/29/09 07:04 PM
11/29/09 07:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
well you can buy mine and I will buy a new set of high compression pistons from Dan
Re: Hemi Piston ? [Re: blowndart] #540475
11/29/09 07:27 PM
11/29/09 07:27 PM
are you using a 6.86conn rod? if so, i have something that will work.
Re: Hemi Piston ? #540476
11/29/09 07:33 PM
11/29/09 07:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
who? me or him
Re: Hemi Piston ? [Re: Quicktree] #540477
11/29/09 07:42 PM
11/29/09 07:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
But the guy asked for a 4.280 BORE for a 4.375 STROKE piston ...
Re: Hemi Piston ? [Re: JohnRR] #540478
11/29/09 07:44 PM
11/29/09 07:44 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi Piston ? [Re: JohnRR] #540479
11/29/09 07:48 PM
11/29/09 07:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
all I seen was 4.375
Re: Hemi Piston ? #540480
11/29/09 07:57 PM
11/29/09 07:57 PM
Odessa, Fl
Odessa, Fl
Yes
Re: Hemi Piston ? [Re: hemi-itis] #540481
11/30/09 11:31 AM
11/30/09 11:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you aren't going to fit in your car if you keep eating all that
