Re: Hemi Piston ?
[Re: blowndart]
#540472
11/29/09 06:42 PM
11/29/09 06:42 PM
Does anyone make an off the shelf piston for a 4.28 bore and 4.375 stroke hemi? I can't seem to find one.
for how much compression with which heads? (chamber size)
Re: Hemi Piston ?
[Re: blowndart]
#540474
11/29/09 07:04 PM
11/29/09 07:04 PM
Quicktree
9.0:1-10.5:1 CR with stock type iron heads.
well you can buy mine and I will buy a new set of high compression pistons from Dan
Re: Hemi Piston ?
[Re: blowndart]
#540475
11/29/09 07:27 PM
11/29/09 07:27 PM
are you using a 6.86conn rod? if so, i have something that will work.
Re: Hemi Piston ?
#540476
11/29/09 07:33 PM
11/29/09 07:33 PM
Quicktree
who? me or him
Re: Hemi Piston ?
[Re: Quicktree]
#540477
11/29/09 07:42 PM
11/29/09 07:42 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I have a new set of JE 4.375s 9:1 for a 4.15 stroke I would probably sell
But the guy asked for a 4.280 BORE for a 4.375 STROKE piston ...
Re: Hemi Piston ?
[Re: JohnRR]
#540479
11/29/09 07:48 PM
11/29/09 07:48 PM
Quicktree
all I seen was 4.375
Re: Hemi Piston ?
#540480
11/29/09 07:57 PM
11/29/09 07:57 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Yes
Re: Hemi Piston ?
[Re: hemi-itis]
#540481
11/30/09 11:31 AM
11/30/09 11:31 AM
JohnRR
U.S.S.A.
you aren't going to fit in your car if you keep eating all that
