SPACE SAVER FOR A 70 CHALLENGER #539394
11/28/09 08:31 PM
11/28/09 08:31 PM
new york
tx9440 Offline OP
tx9440  Offline OP
new york
I am in need of some help. I am looking to find out the size of the space saver for my 70 challenger 440 car. The vehicle has 14 inch rally wheels on it and believe it to be correct(original 21,000 miles). I do not have a build sheet so all I can do is assume by the restorations books i have read. Also the vehicle has a rear defroster and have seen some original paper work stating that this would require a space saver. I have been told that w/14 inch rally wheels the space saver would be E-78-14 with a 14x5 1/2 wheel with a part #2944236. I found this space saver on the internet and the guy wants $550.00 restored. Any help would be greatly appreciated. Thank you
1965 GTO 4 spd tripower convert 1966 GTO 4 spd a/c factory red on red 1969 1/2 Superbee 4 spd butterscotch 1970 Challenger RT 440 4 spd factory black on black
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: tx9440] #539395
11/28/09 09:05 PM
11/28/09 09:05 PM
MD
floyd Offline
floyd  Offline
MD
You should have a f78-14 BF Goodrich Space Saver. The correct rim is a Kelsey Hays (KH) and there is no Chrysler part number on it. As far as I know no 70-71 E-body came with an E-78 space saver. Do a search here in moparts. There have many of threads on this topic. You may want to post over in the Resto section too. Do some research before buying. There are a lot of mis-informed sellers (and shysters) out there hoping to score big money on the compact spare confusion.
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: tx9440] #539396
11/28/09 09:05 PM
11/28/09 09:05 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
F78-14
B.F. Goodrich
No ribs on inner wheel around lug nut holes. Area should be flat.
Six holes. 5 lug nut and 1 stamped locater hole directly across from valve stem. Black.
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: Snoopy] #539397
11/28/09 09:06 PM
11/28/09 09:06 PM
MD
floyd Offline
floyd  Offline
MD
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: tx9440] #539398
11/28/09 09:27 PM
11/28/09 09:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
IS there a donut from a new mopar that will work?
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: tx9440] #539399
11/29/09 12:58 AM
11/29/09 12:58 AM
Snoopy Offline
Snoopy  Offline
Read this post before you do anything.
70 'Cuda full size spare wheel (Rim) size?
The part number, 2944236, you listed is for a full size spare.
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: tx9440] #539400
11/29/09 03:58 AM
11/29/09 03:58 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Required only with dual speakers and rear defogger, otherwise it would be an extra cost option as with any other 14" equipped hardtop.
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: tx9440] #539401
11/29/09 11:57 AM
11/29/09 11:57 AM
new york
tx9440 Offline OP
tx9440  Offline OP
new york
I am confused. I thought if the car came with 15 inch rally wheels then you would have a F-78-14(7.75-14) space saver and E-78-14(7.35-14) if the car has 14 inch wheels. Also does build date play a part in the space saver size. My build is 3/70 which puts it 6 months into the model year(exactly mid year).
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: tx9440] #539402
11/29/09 02:41 PM
11/29/09 02:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
See the page at this link;
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Challenger0020.jpg
Also see W34 (and H31) on this page;
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Challenger0021.jpg
R31 here;
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Challenger0023.jpg
The tire size noted at the first link is the early one, it did change during the model year.
I do not see any mention of the space saver being required with R31 or H31?
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: Alaskan_TA] #539403
11/29/09 03:25 PM
11/29/09 03:25 PM
new york
tx9440 Offline OP
tx9440  Offline OP
new york
Thanks for all the info. I think if i put it all together I should have a space saver that is a 14x51/2 rim with no part number with a BFG F-78-14 tire .
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: tx9440] #539404
11/29/09 03:46 PM
11/29/09 03:46 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The spare tire hold down theaded rod was in a different location for space saver spares as compared to the full size spares. If your trunk is original post a pic of the hold down area.
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: ScottSmith_Harms] #539405
11/29/09 09:26 PM
11/29/09 09:26 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
______________________________________________
Would someone be kind enough to post pics of the locations. My RT/SE has a rear defroster and two rear speakers. I received the car without any spare or jack.
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: gomangoRTSE] #539406
12/01/09 05:12 PM
12/01/09 05:12 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
_________________________________________________
Ummmm
Re: SPACE SAVER FOR A 70 CHALLENGER [Re: gomangoRTSE] #539407
12/01/09 06:21 PM
12/01/09 06:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.click on word "attachment" to enlarge
