Anyone use this stroker kit from Mancini??
#539041
11/28/09 01:36 PM
11/28/09 01:36 PM
Posts: 25,964 United Socialist States of Ame...
tboomer
MANCINI - 493 ci 440 Flattop piston Stroker Kit Kit includes: Diamond flat top lightweight forged pistons wit .990 pin and Diamond moly piston ring set. Eagle 4340 forged crank with 2.200" rod journal. Eagle ESP H-Beam rods. Clevite Tri metal rod and main bearing set. $1,450.00 MRE440-493-FLAT Opinions??? Looks like a pretty good deal!!
Re: Anyone use this stroker kit from Mancini??
[Re: tboomer]
#539044
11/28/09 02:00 PM
11/28/09 02:00 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Thats a deal...Those are premium part... a bunch better than other low cost kits.. I would jump on that.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: dOOc]
#539050
11/29/09 11:05 AM
11/29/09 11:05 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Balanced ?
I would not pay for the balance job , unless it was adding another 300 or so to the cost , you buy a 150 balance job you GET a 150 balance job ... which entails LOOKING at the weights written on the box
[Re: JohnRR]
#539051
11/29/09 04:51 PM
11/29/09 04:51 PM
tboomer
Thanks,guys!! Kevin...You are 400# less than me!! No heads up! John...You are so right on the balancing act!! I will call tech at Mancini when I have the time...Curious about compression ratio with my 80cc heads.. I have a lot of irons in the fire at this time with dad passing on and a boatload of OT at work..I am scheduled for 56 hours this week and 66 hours next week! Ted
[Re: Streetwize]
#539052
11/29/09 05:06 PM
11/29/09 05:06 PM
Good parts for a good price, I'd still prefer the 4.25 stroke if you can get it.
but if a 4.25 is not an option, thats a great deal, i'd jump on that,wish that price was around when i did my last motor, could of saved a bunch of $$$$.
[Re: DaytonaTurbo]
#539055
11/30/09 07:52 PM
11/30/09 07:52 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Must be the name of who sells the kit makes them better than some of the other low buck stroker kits out there. There all the same, diamond, ross, or keith black pistons , unnamed h-beamed rods and crank . I must say that is a good deal. How much for a balance job?
[Re: rowin4]
#539057
11/30/09 08:43 PM
11/30/09 08:43 PM
DaytonaTurbo
Manitoba, Canada
They sell the same kit but internal balanced for an extra 300 bucks. I think most people will pay their local machine shop to do it.
[Re: mopar65]
#539058
11/30/09 08:57 PM
11/30/09 08:57 PM
tboomer
Thanks for the condolence,Bobby...I have a bunch of things going on with that,as I am executor(sp)..Yes...the 508 was discussed..Really thought hard about that one!! It is just a bracket car...With the 493...We can start from the ground up and know what we have...
[Re: rowin4]
#539060
11/30/09 10:54 PM
11/30/09 10:54 PM
JohnRR
U.S.S.A.
No , it's alot more than just who is selling it , and if you think they are all the same then you should just buy the cheapest ...
