68 b body disc brake retro
#536091
11/24/09 10:41 PM
11/24/09 10:41 PM
Posts: 4,872 connecticut
pnypwr
connecticut
will a sgl piston set up work with the sway bar on a 68 runner? I believe these are late a body spindles and discs as they are not the pin type? Just wondering if I should save them for the 68 or not thanks
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
Re: 68 b body disc brake retro
[Re: pnypwr]
#536093
11/25/09 01:09 AM
11/25/09 01:09 AM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
That's the setup to use. Apparently they will interfere with the swaybar but since you've swapped brakes you may as well swap swaybars too! I guess the '70 swaybar is supposed to be the ticket. Moving the spindles side to side to move the calipers to the back apparently causes hose problems. Read all about it here ... http://www.moparaction.com/Tech/archive/disc-main.html
[Re: Stanton]
#536095
11/25/09 01:32 AM
11/25/09 01:32 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
... Moving the spindles side to side to move the calipers to the back apparently causes hose problems...
Those problems can be overcome by just ordering the right set of brake hoses and a banjo bolt. Or buying braided hoses with banjo end and a banjo bolt.
You're going to have to buy brake hoses anyway, so just figure out the right ones to buy.
[Re: Y2RR]
#536100
11/30/09 10:31 PM
11/30/09 10:31 PM
pnypwr
connecticut
did you have to change the caliper bracket to run the doba rotors?
[Re: pnypwr]
#536101
11/30/09 10:50 PM
11/30/09 10:50 PM
Posts: 10,213 Someplace you aren't
SomeCarGuy
What about running Viper calipers using the AndyF brackets? Would that take care of the swaybar and hose issues? BTW, I have found the Russell SS braided hoses to be the same price as rubber hoses. Have to order the drum brake set even if you have discs swapped on a B or E body. I think the disc set is for Wilwood brakes as it has two female ends.
I want my fair share
