68 b body disc brake retro #536091
11/24/09 10:41 PM
11/24/09 10:41 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
will a sgl piston set up work with the sway bar on a 68 runner? I believe these are late a body spindles and discs as they are not the pin type? Just wondering if I should save them for the 68 or not thanks
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 68 b body disc brake retro [Re: pnypwr] #536092
11/25/09 12:43 AM
11/25/09 12:43 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Shouldn't be a problem and you can always mount the calipers toward the rear.
Re: 68 b body disc brake retro [Re: pnypwr] #536093
11/25/09 01:09 AM
11/25/09 01:09 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That's the setup to use. Apparently they will interfere with the swaybar but since you've swapped brakes you may as well swap swaybars too! I guess the '70 swaybar is supposed to be the ticket. Moving the spindles side to side to move the calipers to the back apparently causes hose problems.
Read all about it here ...
http://www.moparaction.com/Tech/archive/disc-main.html
Re: 68 b body disc brake retro [Re: Stanton] #536094
11/25/09 01:22 AM
11/25/09 01:22 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
misleading information in that article about the F, M, J and late B spindles being something to stay away from its hogwash
Re: 68 b body disc brake retro [Re: Stanton] #536095
11/25/09 01:32 AM
11/25/09 01:32 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
... Moving the spindles side to side to move the calipers to the back apparently causes hose problems...
Those problems can be overcome by just ordering the right set of brake hoses and a banjo bolt. Or buying braided hoses with banjo end and a banjo bolt.
You're going to have to buy brake hoses anyway, so just figure out the right ones to buy.
Re: 68 b body disc brake retro [Re: Stanton] #536096
11/25/09 07:33 AM
11/25/09 07:33 AM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
changing sway bars involves changing k frames to a 70 b body k, whishisnt the easiest or most inexpensive to find,
thanks for the responses, I was going to go braided stainless anyway
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 68 b body disc brake retro [Re: pnypwr] #536097
11/25/09 09:48 AM
11/25/09 09:48 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The calipers have to hang on rear, and the hoses are the only issue. I ended up using some early nineties ford E van hoses, but heard that there is hope for some aspen volare hoses also.
Re: 68 b body disc brake retro [Re: buildanother] #536098
11/25/09 12:33 PM
11/25/09 12:33 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I used '73 Charger hoses on my '64 where I mounted the calipers to the rear. These hoses have the least amount of hard line on them so they're more flexible. I don't know how similar the brake hose mounting is between the '64 and '68.
This is the '73 Charger hose.
This is a '73 Dart hose which had too much stress on it when the car was on the ground.
Re: 68 b body disc brake retro [Re: NicksGarage] #536099
11/30/09 08:35 PM
11/30/09 08:35 PM
Chilliwack, BC, Canada
Y
Y2RR Offline
Y2RR  Offline
Y
On my 69 RR I used 75 Dart spindles and had to reverse them to avoid the sway bar. Like the various magazine articles and other members have mentioned, I also used 1979 Aspen brake lines and an Aspen station wagon proportioning valve. Also used the larger Cordoba rotors and later model B body calipers. Been using this system for the past 6 years and no problems.
Re: 68 b body disc brake retro [Re: Y2RR] #536100
11/30/09 10:31 PM
11/30/09 10:31 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
did you have to change the caliper bracket to run the doba rotors?
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 68 b body disc brake retro [Re: pnypwr] #536101
11/30/09 10:50 PM
11/30/09 10:50 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What about running Viper calipers using the AndyF brackets? Would that take care of the swaybar and hose issues?
BTW, I have found the Russell SS braided hoses to be the same price as rubber hoses. Have to order the drum brake set even if you have discs swapped on a B or E body. I think the disc set is for Wilwood brakes as it has two female ends.
I want my fair share
Re: 68 b body disc brake retro [Re: SomeCarGuy] #536102
11/30/09 11:52 PM
11/30/09 11:52 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
prob coz fatory its a 4 piston setup and the caliper has a hard line that runs to the hose, least thats how it is on my amx and the mopar calipers are similar!
Viper parts sound cool, but that opens a whole other can of worms, with wheel size, and master booster combos...
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 68 b body disc brake retro [Re: pnypwr] #536103
12/01/09 01:03 AM
12/01/09 01:03 AM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
I have a 69 charger 75 dart spindles 76 charger cliper brackets pin type 71 charger calipers mounted to the rear auto zone 15.00 ,no core .hose stop flex braided was custom made to my spec classic tube 40.00 to my door,12inch cop car rotors,73 charger combination valve.hotchkiss sway bar firm feel steering box
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
