Page 2 of 3 1 2 3
Re: Let's see your Dodge Dakota Roll Cages [Re: 8secDart] #535850
01/24/11 05:03 PM
01/24/11 05:03 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
Here are some of my truck.Updating to go headsup racing.Need to go 5.30s in the 1/8 on stock suspension.Hope to have it done by the first of the year.
I love this cage, but I called an NHRA tech director and he said in not so many words that it would not certify. It basically needs the down bars to the rear frame for certification, is what i was told, even with the funny car cage.
Now, that doesnt mean a local guy wouldnt have certified it, but I guess I cant take that chance.
Lenny, have you had yours certified, or plan on it?
justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Let's see your Dodge Dakota Roll Cages [Re: julian2007] #535851
01/24/11 05:55 PM
01/24/11 05:55 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
Dont have any photos of the cage but it was built so the driver set back in the club cab and the motor was set back as well.the result was 49.5% rear weight, the truck 60 fted very well and would hook on any track,also with the motor set back a hooker super comp b-body header worked with a small mod.Get that weight on the rear and it will serve you well.If I can find any more photos I will get them to you.
Did you move your motor back 5"? I thought I read something about you doing so. I wonder if moving mine back 2.5" will make a difference at all?
2000 dakota 418 magnum paxton novi 2k T56
Re: Let's see your Dodge Dakota Roll Cages [Re: Sick 660r] #535852
01/24/11 06:50 PM
01/24/11 06:50 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
My local Cert guy come over and looked before paint.He said that it will pass.I went as far as to tell him I'd put the bars in for the cert but they would be cut out before paint,LOL
He told me on the trucks the SFI is a little grey area.
Re: Let's see your Dodge Dakota Roll Cages [Re: 8secDart] #535853
01/24/11 07:17 PM
01/24/11 07:17 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
maybe I need to come down there to get certified. I hate those bars.
Re: Let's see your Dodge Dakota Roll Cages [Re: wldtm] #535854
01/24/11 07:41 PM
01/24/11 07:41 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
justin
I don't wanna start an argument, but same here in Cali, the tech directors said they wouldn't cert it and promoters said they wouldn't let it run.
Re: Let's see your Dodge Dakota Roll Cages [Re: Devilbrad] #535855
01/24/11 08:02 PM
01/24/11 08:02 PM
8secDart Offline
8secDart  Offline
If it has a tag how can a the track say it can't run.This is the problem with the trucks every other person has a differet outlook on the rules.
My cert guy said if it had a funnycar cage it was legal.That is all I needed!!!!!!!!!!!
Re: Let's see your Dodge Dakota Roll Cages [Re: 8secDart] #535856
01/24/11 11:13 PM
01/24/11 11:13 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
This is a c/m cage. I still havent got a chance to carpet it put my ppp shifter and kirkeys in yet so dont judge lol.
Re: Let's see your Dodge Dakota Roll Cages [Re: 8secDart] #535857
01/24/11 11:14 PM
01/24/11 11:14 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
is it 25.5 7.50 cert or sportsman 8.50 cert?
....BAD A$$ STREET CAR.....
Re: Let's see your Dodge Dakota Roll Cages [Re: ChrisJohnston669] #535858
01/24/11 11:16 PM
01/24/11 11:16 PM
8secDart Offline
8secDart  Offline
Cage looks killer.Here is mine all done.I still need to mount the pass seat.
Re: Let's see your Dodge Dakota Roll Cages [Re: n20mstr] #535859
01/24/11 11:18 PM
01/24/11 11:18 PM
8secDart Offline
8secDart  Offline
Mine or his,LOL
mine is only 8.50
Re: Let's see your Dodge Dakota Roll Cages [Re: TheOtherDodge] #535860
03/16/11 08:31 PM
03/16/11 08:31 PM
Charlotte, NC
340Dart Offline
340Dart  Offline
Charlotte, NC
I just was reading through some of the posts and I saw your question on the window nets, the cages and nets in the Dakotas came from AutoWeld - in Pa. I own the Blue Dakota that Lenny is building, I bought the first cage from them, the cage fit extremely well, Lenny was impressed enough to order his cage from them also.
http://autoweldchassis.com/rbc.ivnu
Steve R
Re: Let's see your Dodge Dakota Roll Cages [Re: 340Dart] #535861
03/16/11 08:43 PM
03/16/11 08:43 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
Even the A-pillar bars are from autoweld?
The problem with the autoweld, is if I do run there set-up I will likely run the kicker bars, and theirs go thru the body, which I would rather the glass (would rather not have them at all).
Thanks for the update, looks good btw.
justin
Re: Let's see your Dodge Dakota Roll Cages [Re: wldtm] #535862
03/16/11 10:27 PM
03/16/11 10:27 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Call Jim Collins he is the NHRA southeast tech director.
I can save you the time. You must have the rear bars unless you cert 25.4 or 25.5. The funny car cage is only part of the requirements in those specs. It's not a grey area. Hate to be the bearer of bad news. You either follow the requirement in the rulebook to certify to 8.50 or follow the roll bar spec for 10.00. Both require the bars to the rear. I have been hashing this out with my customer for over a year now. Problem is he sees guys with illegal cages running at the track. Have a hard time explaining that VMP or Bristol is going to send you home if you don't have what is required.
Here is a pic of a currently illegal cage per customer request. We are looking into adding to it which is far harder now than doing to begin with. The rear bars are to keep the cage from being rolled off of the driver. I put the dash bar through the A-pilars so it aint coming out. But, rules are rules. The door bars are not installed yet. Can't work around them.
Leon
Re: Let's see your Dodge Dakota Roll Cages [Re: Leon441] #535863
03/16/11 10:33 PM
03/16/11 10:33 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
im not a huge fan of trucks,but lennys truck makes me kinda weak in the knees
Re: Let's see your Dodge Dakota Roll Cages [Re: Leon441] #535864
03/17/11 11:24 PM
03/17/11 11:24 PM
8secDart Offline
8secDart  Offline
Leon
Leon mine has all the bars they call for!!!!!!!!!!
The rocker bars are under the rocker real tight.I think it just depends on the tech guy.I have a lot of kicker bars in places most would not put them.
I'am going back to running on the street so all the tech guys can kiss my redheaded butt!!!!!!!!!!!LOL
Re: Let's see your Dodge Dakota Roll Cages [Re: 8secDart] #535865
03/18/11 09:30 PM
03/18/11 09:30 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
If the cage is certified the tech guy is out of the picture all together. If there is any doubt cary the spec. around with you. It either passes certification or not. All sanctions I know of honor the SFI spec. NHRA and IHRA honor it for sure. So a bold tech guy means nothing.
I can tell you this I had a little experience with a tech guy in Florida. He was a smartaz and was saying my car was not legal, but he was going to be nice and let me run. I was using the VIN for a chassis number instead of a stamped plate on the cage. Jim Collins had certified the car. I pulled the paperwork(receipt more or less) out of the glove box that was given to me with Jim's signature at the bottom. Lets just say the little smartaz got real weak in the knees and started backing up on what he had been saying.
The chassis now has a plate with the VIN on it. Did that when I upgraded to 25.2.
Re: Let's see your Dodge Dakota Roll Cages [Re: Leon441] #535866
12/05/11 06:05 PM
12/05/11 06:05 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
bump on an old thread. does anyone have any pics of how they tie the cage to the frame? any pics would be appreciated. Specifically the A pillar bars.
thanks
Justin
Re: Let's see your Dodge Dakota Roll Cages [Re: wldtm] #535867
12/05/11 08:25 PM
12/05/11 08:25 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
thanks
Justin
No pics, but when I was asking the guys at Kammers once, they told me that you could weld the cage inside the cab to a steel plate, which is welded to the floor as well, then weld another plate to the frame, and use bolts through the plates to hold it all together.
or cut holes in the factory floor and weld the tubes to the frame.
I was just shooting the bull with them while I had my big block on their dyno, and they were talking about how they race some Dakota's, they asked if I wanted to race mine or not. just some chit-chat between dyno pulls, since I had no intention of building a race only truck, it was full trim, full factory interior, full factory sheetmetal street "fun truck"
**Photobucket sucks**
Re: Let's see your Dodge Dakota Roll Cages [Re: 70Cuda383] #535868
12/05/11 08:36 PM
12/05/11 08:36 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
The Kammer guys build a lot of engines for Dakota stockers. Great people! WLDTM, the trucks I have seen all had outriggers welded off the frames towards the rockers, they were tied together, and the roll cage landed on top of the outriggers.
Re: Let's see your Dodge Dakota Roll Cages [Re: Devilbrad] #535869
12/05/11 08:38 PM
12/05/11 08:38 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
thats the way my dads is done. you got any pics brad???
I guess i could go to kammers, since it is a whole 30 minutes away.
Page 2 of 3 1 2 3
